P1182 & P0068
Old Jun 15, 2008 | 12:02 PM
Hopeless Regret's Avatar
P1182 & P0068
Everytime I go to WOT it hesistates bad at 6grand and then check engine light comes on and these are the 2 codes I get. Spark plug gap at .032. Any Ideas?
Old Jun 15, 2008 | 12:06 PM
Joeyavhu's Avatar
For others reference to help you figure this one out.
P1182 Supercharger Inlet Pressure Sensor Performance -PCM
P0068 Throttle Body Airflow Performance -PCM
Sorry, thats a tough one. I wish I could help more.
Old Jun 15, 2008 | 12:19 PM
HOT CARLS SS's Avatar
Gap the spark plugs at .030" or .028" I had the same problem at 6500rpms to 7000rpms. I am running the Iridium BKR7EIX's at .028" you can gap these plugs but you have too be carefull...try this.
Zach06CobaltSC's Avatar
With those codes I would take apart the throttle body and make sure theres no "gunk" in it. Also make sure all the vacuum lines to your supercharger are good to go, and around in the engine in general.
This is just my 2 cents, I hope it helps.
Old Jun 15, 2008 | 12:22 PM
I've tryed gapping the plugs smaller and it works but it still cant get to 7000 without throwing those codes. Ive checked every vacuum line possible - I was thinking maybe the intake gasket is leaking - I had a new head put on around 20,000 miles ago but I dont know if they reused the same intake gasket.
BumbleBeeBalt
Feb 15, 2013 07:01 PM
crammers
Jan 29, 2013 08:22 AM
crazysteve
Jul 28, 2009 09:34 PM
persiani
May 20, 2009 02:22 PM
Zach06CobaltSC
Jun 16, 2008 03:32 AM
