P1182 code
Old May 20, 2009 | 01:09 AM
persiani's Avatar
P1182 code
P1182 Supercharger Inlet Pressure Sensor Performance
would i throw this code if my MAF or SCIP sensors are dirty??
or i have a leak some where between my intake and sc??
ihave thrown this code but cant seem to figre out what it is.
i installed 2.8/60s/and got tuned. would it be from the tune??
Old May 20, 2009 | 01:15 AM
BoostedYards86's Avatar
who tuned u? have them turn off that code...end problem
or it could just be a dirty tb...
Last edited by BoostedYards86; May 20, 2009 at 01:15 AM. Reason: Automerged Doublepost
Old May 20, 2009 | 09:19 AM
Coblasts's Avatar
Check for the following
• Disconnected, damaged, or incorrectly routed vacuum hoses
• A supercharger or engine vacuum leak
• A misaligned, loose, or damaged air intake duct
• Any objects blocking the air inlet probe of the mass air flow (MAF)/Intake air temperature (IAT) sensor
• Any contamination or debris on the sensing elements in the probe of the MAF/IAT sensor
• Any damage or fractures to the SCIP sensor housing
• A missing or damaged SCIP sensor seal
• Restrictions or debris in the SCIP sensor vacuum port
Old May 20, 2009 | 02:16 PM
persiani's Avatar
I checked my hoses and checked for leaks and have non, the mad sensor never came off when I did the install but the supercharger sensor did, everything is alignamd right and the car pulls like a beast but the light is there, the tb is clean as I cleaned it. When I did the install, only thing I can think of is the supercharger sensor is dirty, if I clean the sc sensor and the maf would that solve my problem
Old May 20, 2009 | 02:22 PM
it will fix the problem for a short while. some cars have a problem with this sensor. mine being one of them. i've never seen this problem on a cobalt tho...mainly redlines. imo shut the sensor down via hpt.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
