Pacesetter header
Pacesetter header
I have a pacesetter header installed but since i cut the ball joint off the exhaust shop cant find a gasket that will last more then a week. What are you guys using?
What kind of flange are you using? Do you have any flex pipe up in there?
I used the stock cat, and the donut flange the header came with... welded it together like the directions said... works just fine...
would something like this work, i need something strong. Im getting tired of my car sounding like **** every 2 weeks.
http://www.fastwrx.com/3in2hoexga.html
I guess I need more info on what they did exactly. Im assuming they cut off the ball joint from the Pacesetter, and welded on a two-bolt flange, because your custom downpipe has a two-bolt flange. BUT, if there is no flex-pipe-section on the downpipe anywhere, that two-bolt flange is absorbing the movement of the motor, which over time, is proba-bly wearing out the gasket. So Im thinking that a new gasket isnt the real fix here
Hope that makes sense
No there is a flex pipe. They cut off the ball joint using a 2 bolt flange on the downpipe with a flex joint on the dp. They said they couldnt get a gasket thats 3 inches so that STI one should work right?
considering most of the high horsepower guys on this forum run and reccomend the pacesetter i made a good choice. I have absolutely no complaints from it, i just need a gasket.
But yes, any 3" two-bolt metallic gasket (like that STi one) would work.
have them weld the downpipe to the header. That's what I did. Makes it all one piece, better for flow, and no more gasket problems. If you ever change the setup, you'll probably have to get a new dp though.
Last edited by ralliartist; Oct 28, 2009 at 11:24 AM. Reason: Automerged Doublepost
What about the o2 sensor bung being on the bottom? I hear thats bad for the sensor that it should be on top. I got my pacesetter header coming soon so I was just wondering if anyone has had problems with there o2 sensor going out?
This is the kinda help i was looking for, thanks.
z28addiction
Sep 28, 2015 12:03 AM
