Pacesetter header
Old Oct 27, 2009 | 01:05 PM
Chase0224's Avatar
Pacesetter header
I have a pacesetter header installed but since i cut the ball joint off the exhaust shop cant find a gasket that will last more then a week. What are you guys using?
Old Oct 27, 2009 | 01:21 PM
NexTnmE's Avatar
What kind of flange are you using? Do you have any flex pipe up in there?
I used the stock cat, and the donut flange the header came with... welded it together like the directions said... works just fine...
Old Oct 27, 2009 | 01:56 PM
Chase0224's Avatar
yeah i have the doughnut flange but no ball joint, and i have a custom 3 inch catless downpipe.
would something like this work, i need something strong. Im getting tired of my car sounding like **** every 2 weeks.
http://www.fastwrx.com/3in2hoexga.html
Old Oct 28, 2009 | 08:06 AM
NexTnmE's Avatar
I guess I need more info on what they did exactly. I’m assuming they cut off the ball joint from the Pacesetter, and welded on a two-bolt flange, because your custom downpipe has a two-bolt flange. BUT, if there is no flex-pipe-section on the downpipe anywhere, that two-bolt flange is absorbing the movement of the motor, which over time, is proba-bly wearing out the gasket. So I’m thinking that a new gasket isn’t the real fix here… Hope that makes sense…
Old Oct 28, 2009 | 09:25 AM
Chase0224's Avatar
No there is a flex pipe. They cut off the ball joint using a 2 bolt flange on the downpipe with a flex joint on the dp. They said they couldnt get a gasket thats 3 inches so that STI one should work right?
Old Oct 28, 2009 | 09:50 AM
Supercharged Guy's Avatar
Dont buy cheap headers like that, they suck go CTI or ZZP cant go wrong with either...
Old Oct 28, 2009 | 09:55 AM
Chase0224's Avatar
considering most of the high horsepower guys on this forum run and reccomend the pacesetter i made a good choice. I have absolutely no complaints from it, i just need a gasket.
Old Oct 28, 2009 | 11:18 AM
NexTnmE's Avatar
Hmmm. Thats strange that it's still blowing out gaskets then
But yes, any 3" two-bolt metallic gasket (like that STi one) would work.
Old Oct 28, 2009 | 11:24 AM
ralliartist's Avatar
you're an idiot
have them weld the downpipe to the header. That's what I did. Makes it all one piece, better for flow, and no more gasket problems. If you ever change the setup, you'll probably have to get a new dp though.
Last edited by ralliartist; Oct 28, 2009 at 11:24 AM. Reason: Automerged Doublepost
Old Oct 28, 2009 | 11:28 AM
BLAZIN07SS's Avatar
I'm too JDM for you
idiot. pacesetter is the most bang for the buck. header, custom downpipe w/ wideband bung cost me $220
Old Oct 28, 2009 | 11:37 AM
Jn2's Avatar
Jn2
I rum the pacesetter and it's a good header. Very cost effective
Old Oct 28, 2009 | 02:27 PM
roderick's Avatar
What about the o2 sensor bung being on the bottom? I hear thats bad for the sensor that it should be on top. I got my pacesetter header coming soon so I was just wondering if anyone has had problems with there o2 sensor going out?
Old Oct 28, 2009 | 03:21 PM
Chase0224's Avatar
Originally Posted by ralliartist
you're an idiot
Okay i already ordered it, the shop said the biggest they could get there hands on was 2, 1/4inch. Thats a good idea, if this one doesnt work ill just have them do that.
x2 i love mine.
I dont have a problem, but i only use the 02 sensor on top, im catless so im tuned for no cat. I just use an LC1 in the bottom spot.
This is the kinda help i was looking for, thanks.
Old Nov 5, 2009 | 06:57 PM
Chase0224's Avatar
BUMP...
3 different gaskets and cant find one, i know a lot of you use pacesetter what gaskets, i really need some help.
Old Nov 6, 2009 | 10:29 AM
NexTnmE's Avatar
the only thing i can think of is that the flange is warped... have them weld up a new one for you...
Old Nov 6, 2009 | 01:11 PM
I already told you, weld it.
Old Nov 6, 2009 | 03:27 PM
Chase0224's Avatar
i gotta check with a garage about doing that, my exhaust shop take off the header, and they said they cant get the gun up in there to weld it.
Old Nov 6, 2009 | 05:22 PM
yea, they'll have to take the header out, weld the dp on, then put the header back on the car, and connect it to the catback.
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
