Pacesetter Header
Old Dec 25, 2009 | 02:26 PM
DEZZIE41's Avatar
Pacesetter Header
what is this header like if i install it will i need a tune>???
Old Dec 25, 2009 | 02:30 PM
Snakes709's Avatar
if u are stock, no tune required. If you are tuned and have stage 2 and then get header/dp/exhaust u will require a new tune. But just with a header...no.
Old Dec 25, 2009 | 02:44 PM
DEZZIE41's Avatar
well my plan is to buy it tomoro...and im getting GM stage 2 next week so still no tune required>?
the only thing it has right now is CAI and a muffler
here is the guys add
Date Listed 24-Dec-09
Price $160.00
Address Nova Scotia B0N 1Z0, Canada
View map
Brand new Pacesetter header Part # 70-1273. Its has 1 3/4" primaries and a 3" collector. It is listed on thier site for 05-06 cobalt SS 2.0 supercharged and 04-06 Saturn Redline 2.0 supercarged. On the box it says Cobalt and Ion.
I was going to put it on a 02 Ecotec 2.2l and it would bolt to the motor but the motor wasn't in a car.
So it should fit on the 2.2l Ecotec Cavaliers. I think it is basically the same header as pasesetter supplies for the 2.2 Ecotecs just with larger primaries to accomodate for larger horsepower gains for the supercharged motor.
Can u tell me if it will work for my 06 SS SC before i do buy it than k
Old Dec 25, 2009 | 03:40 PM
Snakes709's Avatar
If its listed as a header for the 2.0 supercharged and redline then it will fit that. But i dont think it will fit the cavi. And thats not going to require a tune anyways.
Old Dec 25, 2009 | 03:41 PM
DEZZIE41's Avatar
i can get it for 100.00 new u think its really worth it>?
Old Dec 25, 2009 | 03:44 PM
DoMiStIc_RuSh_06's Avatar
be carefull with the pace setter header....I have read quite a bit about them being junk. And the fact that you have to have a custom dp made due to the ball/ socket style flange.
Old Dec 25, 2009 | 03:45 PM
DEZZIE41's Avatar
o ok well screw that game then
Old Dec 25, 2009 | 04:10 PM
Snakes709's Avatar
order 4into1 header/2.5" downpipe and 2.5" exhaust from CIA. Dan there is a good guy and helped me out with my order.
Old Dec 25, 2009 | 06:32 PM
Jn2's Avatar
Jn2
I run the pacesetter, damn good header, bolted right up to my lsj dp once i made 1 cut and 1 weld. Easy ****.
Old Dec 26, 2009 | 12:20 AM
RednBlack's Avatar
I had a custom flange welded to mine but be aware I hag to grind around the welds where the exhaust tubes meet the header flange due to the bolts no being able to go on due to the welds being so high
Old Dec 26, 2009 | 05:56 AM
ralliartist's Avatar
pacesetter header is good ****. well worth the small amount of money.
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
