Pacesetter Question.
Old Jul 21, 2006 | 01:36 PM
Ern's Avatar
Ern
If I were to get the Armor coated one that requires a bit of welding, what downpipe will work with this header?
Old Jul 21, 2006 | 02:07 PM
CTCOBALTSSS's Avatar
I think the ZZP downpipe would work. Hopefuly someone can confirm or deny that.
Old Jul 21, 2006 | 02:17 PM
Ern's Avatar
Ern
I sure hope so becuase I wanna buy the zzp downpipe.
Old Jul 24, 2006 | 03:10 PM
Ern's Avatar
Ern
Bumpity bump
Old Jul 24, 2006 | 06:30 PM
97cavie24ls's Avatar
pacesetter's is made to work with the stock cat , you are required to cut the stock pipe at the weld on the cat case , which should open the cat to 3" , stock pipe is 2 3/4"
Old Jul 24, 2006 | 06:33 PM
Ern's Avatar
Ern
So I cant use an aftermarket downpipe with this header?
Old Jul 24, 2006 | 06:38 PM
pacesetters header is longer than a header that replaces the stock manifold
so you would have to have a shop custom make you a down pipe , or modify 1 that is out there
Old Jul 24, 2006 | 06:39 PM
TurboTechRacing's Avatar
You dont need one, the pacesetter is a 3"
With the pacesetter header you get both the header and the downpipe, which connects to the stock exhuast just before the cat converter. Just like Eric stated.
Old Jul 24, 2006 | 06:47 PM
BlkSS4dr's Avatar
well how abou the 2.4.......
Old Jul 24, 2006 | 07:16 PM
2.4 has no ETA yet, the 2.0 is due out about August 15th but there is no estimated date yet on the 2.4L VVT.
Old Jul 24, 2006 | 07:43 PM
Ern's Avatar
Ern
Ok, so will it mount to my magnaflow catback?
Old Jul 24, 2006 | 07:46 PM
No, the cat back (Magnaflow) connects after the cat converter. The header connects just before the cat converter. So if you would do the pacesetter header and magnaflow cat back, you will still have the stock cat converter in place. This is done due to emissions.
Old Jul 24, 2006 | 07:49 PM
Old Jul 24, 2006 | 07:57 PM
Ern's Avatar
Ern
man this is starting to suck.
Old Jul 24, 2006 | 08:24 PM
Ern's Avatar
Ern
Ok I did some thinking. What if I get the pacesetter, install a testpipe where the cat is supposed to be and use the 2.5 flange from the stock cat and weld it to the end of the test pipe so I can still use my magnaflow? Then weld the end of the header to the other end of the test pipe.
That sounds like it would work.
Old Jul 24, 2006 | 08:31 PM
That would be a way to do it.
Old Jul 24, 2006 | 10:32 PM
Ern's Avatar
Ern
You think that would work very well? If so, you guys are getting another sale from me hehe.
Sean Cummings
Jan 8, 2020 10:17 AM
Dustin24
Oct 8, 2015 09:15 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
Danny Reed
Drag Racing
Aug 31, 2015 10:55 PM
