PB 2.8" install
Old Oct 12, 2006 | 05:58 PM
godsfshrmn's Avatar
PB 2.8" install
I have the gm stage 2 hub on my S/C. I am having trouble getting the PB 2.8" to fit over the hub. There is so little room to work with. How did you guys get yours to fit on the S/C hub? Did you have to pull the S/C to get it on there?
Old Oct 12, 2006 | 06:12 PM
DTM2188's Avatar
Hey man, glad to see it came in on time. When I put it on it just slid right on. I had a tough time getting the extra slack from tensioner to put the belt back on, but not the pulley on the hub.
Old Oct 12, 2006 | 06:14 PM
godsfshrmn's Avatar
Thats odd I cant get it on there at all. I've tried using a rubber mallet with what room I do have and it still won't
Old Oct 12, 2006 | 07:08 PM
DTM2188's Avatar
Friendly bump for an answer.
Old Oct 12, 2006 | 07:18 PM
Tomtwtwtw's Avatar
That is interesting...it should slip right on. I would compare it to your 3", and inspect the hub closely as well to see where the defect is. I wonder if the stage 2 hub and pulley could have warped slightly during use? I don't see how, but I suppose anything is possible.
You could also try putting the 2.8" in the oven for a while. If it's a really close fit, that may do the trick. Many people do that when putting a new hub on the s/c, but it might help here, too.
Old Oct 12, 2006 | 08:49 PM
godsfshrmn's Avatar
We finally got it on there. I went to autzone and got two longer bolts and did it that way. It sure does pull harder and up in the boost early
Old Oct 12, 2006 | 09:19 PM
DTM2188's Avatar
Good to hear, enjoy!
Old Oct 12, 2006 | 09:29 PM
SS33's Avatar
I had the same problem, It is because the stock tensioner "nut" is garbage. Mine was rounded off half way through the Stage 2 install. If you had to run longer bolts than something is wrong. If they are fully threaded they may be rubbing on the snout. OR if they are not fully seated than you will have slop/rattle in that assy. That is very bad.
You just need to use a breaker bar with a solid leverage point and compress the tensioner that way. Makes doing the swap much easier. That stage 2 belt rocks with either the 3" or 2.8" I havent had any slip yet.
Also, if you didn't, you should have bought the bolts from PB, they are much easier to work with IMO
Old Oct 12, 2006 | 09:56 PM
astrocrep's Avatar
Will the stock s2 bolts work w/ the 2.8" If I pull them out, will I have problems putting them back in?
-Rich
Old Oct 13, 2006 | 06:53 AM
SS33's Avatar
-Rich
Yes they will work, but like I said, there are better bolts available. Lots of people have had trouble removing the blue bolts. I haven't heard of anyone having probs with the PB ones
Old Oct 13, 2006 | 10:21 AM
2K5SS/SC?'s Avatar
SS33, I think he used the longer bolts to pull the pulley onto the hub sort of like how you put the hub onto the shaft. :
I reused my stage 2 bolts so I could hide the swap from my very attentive buddies.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
