PCM Question
Old May 20, 2008 | 03:15 PM
Drakonen2000's Avatar
PCM Question
...ok, so who on here knows if i can drop a PCM out of a diff. balt (same year and trim, diff VIN) in my car? will it work, or will i need to wait for HPT and change the VIN before it will work?
Old May 20, 2008 | 04:11 PM
shsballa023's Avatar
Bump for ya. Im guessing you might have to wait for hptuners man. But idk
Old May 20, 2008 | 04:18 PM
Area47's Avatar
Rent me! per hour
05 is different
06 is different
07 is different
you can however over write the 05-06 with either OS, but not 07's.
Old May 20, 2008 | 04:20 PM
Originally Posted by Area47
05 is different
06 is different
07 is different
i have an 06, and i am getting an 06....just wondering if im going to have to change the VIN
..and will i have to do a crank learn (or whatever you call it)?
Old May 20, 2008 | 04:24 PM
Area47's Avatar
Rent me! per hour
yepo. all of the above.
Old May 20, 2008 | 04:26 PM
aw shucks
*kicks the dirt*
Old May 20, 2008 | 04:27 PM
Hahn RaceCraft's Avatar
Two things:
  • VATS relearn (security)
  • CASE relearn (crank angle)
The first you can do without equipment, its easy, Google away, hit me up if you can't find it.
The second requires a Tech II or other scan tool that performs CASE relearn. MSD's DashHawk does it, and it's affordable and very useful too. Available everywhere!
Old May 20, 2008 | 04:29 PM
Area47's Avatar
Rent me! per hour
dash hawk doesn't work on the lsj
Old May 20, 2008 | 04:33 PM
Originally Posted by EcoBoost
Two things:
well...im going to be getting HP Tuners....so im guessin it could do the CASE?
X2...i was just thinkin that
Last edited by Drakonen2000; May 20, 2008 at 04:33 PM. Reason: Automerged Doublepost
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
