Pics please
Old Jan 27, 2006 | 12:00 AM
bluecobaltss06's Avatar
Pics please
I did a search on here because I remember seeing a picture of the bypass mod. Unfortuonetly I didn't find anything. If anyone has any pics they could post up really quick that would be much appreciated.
Old Jan 27, 2006 | 12:02 AM
p7x's Avatar
p7x
I don't suggest it but check the redline forums
Old Jan 27, 2006 | 01:26 PM
So is it possible to push more than the stock 12.5 lbs with out doing this mod? after a pully swap of course
Old Jan 27, 2006 | 01:48 PM
silverSS's Avatar
depending on the pulley size is how much boost you will see..
For example..
With a 3" pulley and the Boost bypass in stock form, which means not touching it and not doing the boost bypass mod..
You will build boost quicker than stock, it will hit 15lbs (depending on elevation)...then drop back down to 12.5lbs from 6-6500k RPM's due to the PCM limiting boost. If you disable the boost bypass then it will hit 15lbs all the way to redline, but the Boost bypass is a engine protection feature, so id leave it, but if you really need that extra power (which i dont feel with the mod, i feel no diff) then go ahead and do it, but be careful
Hope I answered your question???
Old Jan 27, 2006 | 02:04 PM
pclear9061's Avatar
some guys on the RL forums have been useing it and have PROVED it was a ~ 10 hp increase ..........
btw heres a pic of it
Old Jan 28, 2006 | 06:28 PM
Mike's SS's Avatar
Isnt that a pic of the one that disables the module entirely at idle. I thought you were supposed to disconect the line at the bottom of the acuator and expose it to air and seal the one at the front of the solenoid.
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
