Piston/Rod combo?
Old Jun 4, 2008 | 09:47 AM
rrutter81's Avatar
Originally Posted by Frosty288
Magnus Uhr is telling me that my block should be reinforced for that kind of power. And with a Swedish guy named Magnus Uhr..I don't know if I can deny.
What do you guys think?
block is rated for 1400 hp i thought. or has been made.
either way 400 hp is fine for the block.
Old Jun 4, 2008 | 10:52 AM
Area47's Avatar
Rent me! per hour
the block. not the sleeves.
Old Jun 4, 2008 | 08:36 PM
cakeeater's Avatar
sleeves.
Old Jun 4, 2008 | 08:40 PM
Witt's Avatar
An echo?
Old Jun 4, 2008 | 08:42 PM
cakeeater's Avatar
me cant read me repost!
Old Jun 4, 2008 | 10:06 PM
TurboTechRacing's Avatar
Originally Posted by victory_red_SS
Pauter and Crower aren't major enough????
They dont make off the shelf rods for the 2.0L. Maybe the 2.2L which are longer.... But not the 2.0L.
Old Jun 4, 2008 | 10:49 PM
Blown 4-banger's Avatar
B93980B-4
That was the part number for my rods. Thats 4 billet steel STOCK DIMENSION LSJ rods.
Old Jun 4, 2008 | 11:23 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Sorry Aaron but they can be bought, maybe not just drop shipped a set at a time.
JBP rods are made by Pauter, as are the HD rods I am using.
These are both 2.0 direct replacement parts.
And I see the crower part # has also been shared.
Old Jun 5, 2008 | 12:04 AM
bolus's Avatar
Originally Posted by Blown 4-banger
B93980B-4
Crower's catalog says:
"B93980B-4
Specs based on stock sample. No changes in dimensions.4 cyl Custom "
So its just their part number for a custom rod. So that means someone has to send them a LSJ rod sample then right? Or do you call them up and just ask for an LSJ replacement?
Old Jun 5, 2008 | 12:05 AM
Witt's Avatar
B93980B-4
Thats just a generic part number for a custom 4 cylinder rod made to stock specs. Any rod made for any 4 banger not in their catalog will have that part number if its a direct copy of the rod you provide them.
http://www.crower.com/pdf/157-172.pdf
Scroll down to page 163 under custom applications.
Edit: ^^Beat me to the punch.
Old Jun 5, 2008 | 04:07 AM
  #36
Well, mine were after all custom. Sorry I couldn't have been more help
Old Jun 5, 2008 | 04:14 AM
  #37
spike's Avatar
my pauter rods will be here next week.....woot.....drunk post
Old Jun 5, 2008 | 05:54 PM
  #38
Yeah they will make them, we are saying not an "off the shelf item" most places will custom make internals
Old Jun 6, 2008 | 05:57 AM
  #39
Yeah, for the right price.
Welcome to my build
Old Jun 6, 2008 | 10:32 PM
  #40
Frosty288's Avatar
Will the cylinder walls have to be rehoned? Or will I need new sleeves? In light of the recent thread created
Old Jun 8, 2008 | 11:51 AM
  #41
Frosty288's Avatar
Old Jun 8, 2008 | 12:09 PM
  #42
2K5SS/SC?'s Avatar
How many miles are on the car? It would be best to have the cylinder walls honed so the new rings seal properly unless you plan on using the stock rings. Stock rods and Diamond forged slugs seem to be where it's at.
As a side note is the meth running any better for you?
Old Jun 8, 2008 | 12:29 PM
  #43
Frosty288's Avatar
52k on the clock. How do you know a good place that can rehone the walls? I'm sure it's a very precise procedure.
I couldn't really tell you. Between that, the boost controller and the BOV the car seems to be kind of angry - think i'm hitting some sort of fuel cutoff. Throttle dies and there is no power, have to let off the pedal and then press it again to get the power back. At the time this happens the SID says traction and stability control failure. Not sure what it is, i'm working on it.
I just need a tune!
Old Jun 8, 2008 | 01:15 PM
  #44
2K5SS/SC?'s Avatar
Definitely need a tune and need to remove the granny control mode! I wonder if HPTuners supports your PCM. You might want to check it out.
As for the 52K on the clock, I would get it honed for the new rings. Any good local machine shop can do the task easily. Just find one that the local racers use. In Charleston there is a place called Simmons that's off the beaten path on a dirt driveway for that matter , but they do phenominal machine work and their prices are more than fare. Recommended by everyone in town, and the Cobalt has ran it's best after they resurfaced my cylinder head!
Old Jun 8, 2008 | 03:35 PM
  #45
Frosty288's Avatar
Quite a noob to actually building a motor. Does the engine need to come out of the car when inserting new cylinders/rehoning the walls? This car is my DD
Northindy
Oct 31, 2015 01:35 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
frost3
Sep 3, 2015 12:20 PM
Josh@ottp
Aug 31, 2015 01:16 PM
TWM Performance
Apr 13, 2006 06:17 PM
