Pistons possibly blew?
Old Dec 27, 2008 | 07:54 PM
ReckleSS's Avatar
Usually:
Dealership + performance mod's = shitty results
Find a reputable shop and stop taking your car to the dealer.
Old Dec 27, 2008 | 08:04 PM
Black SS/SC 06's Avatar
Originally Posted by ReckleSS
Usually:
QFT!
Old Dec 27, 2008 | 08:10 PM
Snakes709's Avatar
Usually:
thats what im doing from now on. Usally i go to a place called Oregans because theres a mechanic that works on my car 95% of the time and doesnt care about my aftermarket stuff, he still uses my warrenty. But lately the people there are getting more and more retarded
Old Dec 28, 2008 | 11:06 AM
Zach06CobaltSC's Avatar
And to answer your above question, no. AC Delco plugs would not cause this issue, neither would to hot/cold plugs. The plug is not the problem.
Old Dec 28, 2008 | 12:18 PM
383_Stroker's Avatar
To Borrow an Image from another thread... The gasket that is leaking is the piece around the plug hole that looks like 2 circles joined together...
Old Dec 28, 2008 | 12:38 PM
Snakes709's Avatar
k, thanks stroker, hopefully i can still pull it off saying the plugs caused it and they will fix the damn thing free of charge. If they do charge me it looks like something i can do, what is the rubber oring called again? And if you know the part number that would be 1000x better.
Old Dec 28, 2008 | 01:45 PM
I think you've got to buy the whole gasket to get them. Mine started leaking immediately after i discovered a loose spark plug, so I would argue with them that the loose plug was the cause and torched the gasket.
If yo have to fix it, here's a link
https://www.crateenginedepot.com/Eco...7-P1775C0.aspx
Old Dec 28, 2008 | 02:41 PM
SSdan's Avatar
It's a valve cover gasket kit, not sure if you can get those seals separately though.
Old Dec 28, 2008 | 02:43 PM
Snakes709's Avatar
well ill see what happends tomorrow, thanks for the help
Old Dec 29, 2008 | 12:48 AM
Dainslaif's Avatar
Originally Posted by Zach06CobaltSC
+1, yelling and screaming won't get you anywhere and I highly doubt court will either. Dealerships get away with crap all the time, however sometimes they do help out the customer. If the car is still under warranty that will help, however the modifications you have done will be a problem. I am interested to see where this goes.
Just a note: with 60lb injectors and meth injection there is no way they'll do warranty work on that engine.
Old Dec 29, 2008 | 08:35 AM
  #36
Snakes709's Avatar
Yes I know that thank you. however im on the phone with them right now and it sounds like they are paying for all the damage because they f*cked up somewheres, either when they were fixing the blown up plugs or by putting the wrong type in.
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
