Place your bets! $5 up for grabs!
Old Oct 19, 2010 | 09:26 PM
  #76
Bluelightning's Avatar
Got Bewst?
Originally Posted by Frew
bump, numbers or ban
Ya this had been quite the dragged out contest lol. I want numbers!
Old Oct 19, 2010 | 09:29 PM
  #77
donkeyballs's Avatar
0/0 blows up on the dyno
Old Oct 19, 2010 | 09:31 PM
  #78
Got Bewst?
Old Oct 19, 2010 | 09:36 PM
  #79
RiceCop's Avatar
just an FYI for you guys, he is having problems with his heat exchanger. He is fixing the issue and we will be tuning it as soon as his new one comes in. If he wants to get into details he can, but I won't since it's not my car.
Old Oct 19, 2010 | 09:42 PM
  #80
Frew's Avatar
lulz
Old Oct 20, 2010 | 02:14 AM
  #81
ecot3c inside's Avatar
how are you going to tune his heat exchanger?
Old Oct 20, 2010 | 07:42 AM
  #82
Frew's Avatar
Well that's simple, he obviously spun a muffler bearing and dump all his turn signal fluid into his intake and blew the welds on it
Old Oct 20, 2010 | 07:49 AM
  #83
defo98's Avatar
279/256
Old Oct 20, 2010 | 08:12 AM
  #84
cobalt2010's Avatar
i think he also broke a canooter valve
Old Oct 20, 2010 | 08:14 AM
  #85
spitefulxcheerio's Avatar
well you guys would have your numbers if ZZP wasn't railinggggggggggg the **** out of me.
They sent me a heat exchanger with a hole in it and won't give me a new one because all their units are "pressure tested before they leave the shop"
The car is running awesome besides the 207* IAT2's. It's making 20.8 lbs of boost at WOT, fuel trims are good and the meth is doing some serious work. I have cooling solutions on the way so it won't be much longer
Old Oct 20, 2010 | 08:24 AM
  #86
Staged07SS's Avatar
Administrator
Administrator
Yikes !!
You need to make some flow improvements. That is an awefully high boost level for a 2.6" pulley.
Old Oct 20, 2010 | 08:48 AM
  #87
Well I'm going by the law of PV=nrT that basically says that once I get the temperature down, the boost will go down with it.
When I'm seeing IAT2's of 160* or something in that general area, it should be in the 18-19 lb range. Plus I'll be running a new exhaust setup (longtubes)
Old Oct 20, 2010 | 08:58 AM
  #88
Staged07SS's Avatar
Administrator
Administrator
Ok.
The long tubes should be a nice improvement (flow wise) over your shorty header & 2.5" downpipe setup.
That sucks about ZZP not sending you a new H/E.
Old Oct 20, 2010 | 09:15 AM
  #89
I'm really pissed about it. I was saving money to build my motor and I will not buy any more ZZP parts. I hate dealing with these vendors that don't care about us at all. They see us as wallets.
I'm in contact with John Powell, Euthanasia and other sources and that's where I'll be getting my parts from now on. It's so much better to deal with people that actually care about you and your situation. I have to give mad props to the 2 guys I mentioned. They're the one's that solved my cooling problems (Euthanasia) and hooked me up with the longtubes (Powell)
Old Oct 20, 2010 | 09:47 AM
  #90
coopercharge's Avatar
207* even with meth that sucks. Pretty high temps.
Old Oct 20, 2010 | 10:23 AM
  #91
383_Stroker's Avatar
My boost tends to go up in the wintertime i think?.. Denser air entering the TB makes more pressure when heated and expands?
Perhaps?
Old Oct 20, 2010 | 10:32 AM
  #92
gwatson650's Avatar
205/180
Old Oct 20, 2010 | 11:37 AM
  #93
csementuh's Avatar
I once received a leaking H/E from them as well. Took many choice words over many phone calls to management to get a new one... Good luck!
Old Oct 20, 2010 | 11:50 AM
  #94
ebristol's Avatar
I don't know what you guys talking about.
I am not sure what I hit with my ZZP S3 HE but it was all twisted and bent. It still does not leak. I might have to take pics of it because I found it pretty surprising...
Old Oct 20, 2010 | 11:54 AM
  #95
csementuh's Avatar
The unit is strong. Not denying that. I still run one on my car. We're talking about leaks from new, AKA not welded fully, burnt through, etc. Different.
Old Oct 20, 2010 | 01:01 PM
  #96
Frew's Avatar
**** the front mount heat exchanger, spray 100% methanol and that's all the cooling you need, long tubes were def a good upgrade shorty header suck, on a 2.6 im right around 17 psi at 7400 rpms
Old Oct 20, 2010 | 01:22 PM
  #97
csementuh's Avatar
I've never seen my IAT2's go over ~140's*F with my setup making ~23lbs of boost on a 2.8" pulley'd TVS. No meth.
GM and Powell did lots of testing on the larger Griffin H/E that OTTP now sells as their S2 exchanger. To say that an add on H/E or a bigger H/E is not a 'good' mod is simply wrong. An add-on H/E has been proved time and time again to lower temps and not let the car heatsoak so quickly. Additional fluid capacity also works wonders. It can not be said that meth is the end all, be all of cooling mods. Not to mention that there is no such thing as 100% methanol, and the large percentage of methanol in your trunk or underhood is a hazard and certainly not DOT legal. Not being too much of a dick, but the opinionated and biased post does little to advance any knowledge.
As you know E85 would be much preferred to meth as meth is a PITA and does not give all of the same results. Meth is a bandaid fix. Since you live in PGH you know there is only a small handfull of stations around that carry E. If it wasn't for the availability problem I would certainly be running E85.
Old Oct 20, 2010 | 04:59 PM
  #98
Frew's Avatar
Sounds like your talking out of ur ass
Old Oct 20, 2010 | 05:12 PM
  #99
Frew's Avatar
You entire post is a train wreck and I don't feel like typing out why on my droid
Old Oct 20, 2010 | 05:24 PM
  #100
csementuh's Avatar
Hmm yes. What my post is is a threadjack, so back to the OP please. Please continue your banter, maybe somebody else will challenge your holier than thou attitude. If you want proof as to why meth is not God, and H/E's work (or they wouldn't be on cars from the factory) then please do some research before making blanket statements. I have nothing against you personally, I just don't want the other kiddies to think that stuff is teh win, without a little tech info.
Just for kicks, it's impossible to distill any alcohol to 100% as some water will always remain. Basic chemistry.
(Posted from a WinMo phone)
