Please help...
Old Jun 5, 2012 | 09:02 PM
TStone's Avatar
Please help...
Wtf.... - YouTube
why why whyyyyyyy
Got retuned.. car ran ******* perfect.....
came home that day and parked it.. spent the night at the girlfriends.. was out all day the next day, didn't touch it.. spent the next night at the girlfriends.. woke up next morning to come home, start the car and this happens.....
why god whyyyyyyyyyyy
Old Jun 5, 2012 | 09:05 PM
cavfiredesire's Avatar
Not sure if cobalts are the same as cavs but it is similar to when we have to do a theft lock relearn...
Dunno why it would do that but..
Old Jun 5, 2012 | 09:06 PM
TStone's Avatar
say what... not following ya
Old Jun 5, 2012 | 09:10 PM
CCrunner84's Avatar
Try unplugging your MAF and see if it'll stay running.
nhanson's Avatar
Does it restart?
My car does this when its cold and then go to restart and will sound like it has cams till it gets over itself and idles fine.
Old Jun 5, 2012 | 09:42 PM
On a cavi you have to do a passlock relearn...
It will do exactly that...start and run for a few seconds.....but I guess im way off base lol
Old Jun 5, 2012 | 10:31 PM
dumpleRL's Avatar
went full rich then lean is it getting fuel?
Old Jun 5, 2012 | 10:39 PM
Bluelightning's Avatar
Got Bewst?
Ya it almost seems like your MAF isn't reading properly.
Old Jun 6, 2012 | 10:20 AM
TStone's Avatar
What if it does?
Wha if it doesn't?
Plan on checking the maf out when I get off work today..
Also, sometimes there is a terrible vacuum leak.. Like it'll idle like its got cams and idle at like 8hgz or whatever. When it normally is like 20hgz.. And when it stalls out like in the video, the vacuum is at like 0hgz..
Also, it only does this sometimes.. Sometimes i start it and it's fine. Sometimes I start it and it just sounds like its cammed and then it'll rev real quick and be normal..
Also have a p1101 code.. It only comes on after driving for like 3-5 minutes.. I can delete it and it'll stay off UNTIL I turn the car off, restart it and drive for a couple minutes..
Just think I should unplug and see what happens?
Old Jun 6, 2012 | 10:54 AM
marth617's Avatar
This same issue happen to me on my 05 SS/SC i had to take it to chevy they repaired it was an electrical issue with the wires cost me $300 to repair :/
Old Jun 6, 2012 | 11:14 AM
TStone's Avatar
What exactly was wrong with it?
Old Jun 6, 2012 | 11:20 AM
marth617's Avatar
They just said the wires were chewed up so they just repaired them.
Old Jun 6, 2012 | 11:29 AM
royce777's Avatar
sounds like you got ripped off
Old Jun 6, 2012 | 11:34 AM
TStone's Avatar
Haha sure does.. Any idea what wires? Someone told me to check the wiring to the maf so maybe that's it
Old Jun 6, 2012 | 11:37 AM
royce777's Avatar
who tuned you
Old Jun 6, 2012 | 11:53 AM
TStone's Avatar
Tom.. Wickedss.. I know it's nothin tune related though. And I left his place the day before with a perfectly running car
Old Jun 6, 2012 | 11:58 AM
marth617's Avatar
Prob did get ripped off but you know what the issue was resolved so its fine it's just money can always get it back.
Old Jun 6, 2012 | 01:19 PM
mrbelvedere's Avatar
try keeping the car running
Old Jun 6, 2012 | 01:43 PM
CCrunner84's Avatar
What if it does?
Wha if it doesn't?
Just unplug it and see if the car starts and runs. It'll basically be in SD mode. If it'll sit there and idle, then the maf is bad, or something is going on with the wiring, look for pinch / rub points, could even be the connector not seated properly.
Old Jun 6, 2012 | 02:00 PM
P1101 Intake Air Flow System Performance -PCM
Old Jun 6, 2012 | 02:30 PM
TStone's Avatar
If I give it a little bit of a gas, the problem is stronger then my foot I guess you could say, and it'll bog down and die.. if I keep it above like 4k for about 30 seconds then it's good to go..
Alrighty..I'll shower and head out to the garage and report back!
Old Jun 6, 2012 | 03:42 PM
sounds like you have a vaccum leak that needs fixed
Old Jun 6, 2012 | 03:48 PM
TStone's Avatar
Where shall I start looking? Line coming from top of the manifold is good. Where else?
Old Jun 6, 2012 | 03:49 PM
because you touch yourself at night
sorry had to do that...
anyway i had something like this happen to me once after i cleaned my throttle body.. ran like ishh then died. also had the 'eng power reduced' on DIC, but anywho i unplugged battery, then after replug i started it twice then i was fine
Old Jun 6, 2012 | 03:50 PM
TStone's Avatar
I'll try that too
