Please Help!
Old Jun 27, 2007 | 12:24 AM
RBC's Avatar
RBC
Unhappy Please Help!
Well this past weekend I went to the track for the second time with this car and was not really impressed. The first time I went my best time was a 14.7 and best 60" time was a 2.4 and best mph was 99. My mods were intake, cat-back, and upper engine mount. The car wheel hopped like crazy so I figured I would get some new tranny mounts to get rid of it. In the proses I got a great deal on a stage 2 kit and topped that off with a 2.85" pulley. I figured this would make a huge difference and boy was I wrong! The wheel hop was lessoned but not gone and a little more wheel spin as expected. I tried launching at all different rpm's and found nothing to be truly suitable. My best time was a 14.3(with my wife in the car) with a 2.4 60' time . My mph kept getting higher but the best mph was my last run and it was a 102. I am also only boosting 15.5 to maybe 16 psi. This just doesn't seem right and the car seems to be pulling really hard. Does anyone have any ideas, comments, or suggestions on how to improve my situation. Thanks in advance.
Old Jun 27, 2007 | 12:29 AM
UmeNNis's Avatar
I've got one - don't try for good times with spare bodies in the car! lol
Old Jun 27, 2007 | 12:42 AM
RBC's Avatar
RBC
agreed on that now my wife thinks she's fat.
Old Jun 27, 2007 | 12:52 AM
NinjaHampster's Avatar
im in the same boat man, so i am subscribing to figure out the best way to do this also
Old Jun 27, 2007 | 01:02 AM
Shanman's Avatar
R/T? if u could get ur 60ft down to 2.2 u should be fine and run 13's
Old Jun 27, 2007 | 01:07 AM
tREBs's Avatar
r/t dosent effect overall time, time starts when you leave the line! have u re-tuned for the 2.85 pulley? or are u running a stg 2 tune? if so get it re-tuned cuz your prolly running lean, also if your going for low times try not to have your wife with you! and like mentioned work on the 60' and you should be golden!
Old Jun 27, 2007 | 01:11 AM
tkaugh29's Avatar
yea if u didnt already, take out the spare tire and jack as well. thats what like 40 pounds togehter
Old Jun 27, 2007 | 02:58 AM
LopsidedJester's Avatar
I heard feathering the clutch helps a lot when taking off, since our axles don't like to take a pounding plus the wheel hop issues. I've run my best times when i had a jetta when the clutch was going cause it allowed it to slip mostly through first gear. Just don't use the clutch so much that you glaze it.
Old Jun 27, 2007 | 03:00 AM
REIGN SS's Avatar
Original Hayden Fanatic
get someone to turn down the boost in 1st gear
Old Jun 27, 2007 | 03:03 AM
DaREDss's Avatar
get that 60 down someone else has same mods axels and i think mounts and runs 13.6 But the 60 was a 2.1 . And 16 psi is right for the 2.85
Old Jun 27, 2007 | 05:00 AM
ThatGuyinApt.D's Avatar
get some better tires?
Old Jun 27, 2007 | 08:27 AM
Shortbus's Avatar
You really need to get your 60ft time down to run some descent times it takes practise. Your trap speed is there just not your 60ft.
Old Jun 27, 2007 | 11:13 AM
Area47's Avatar
Rent me! per hour
you're not running the max amount of timing that you could.
in short, it's getting knock retard.
Old Jun 27, 2007 | 12:26 PM
rnjmur's Avatar
I have to agree... you need to work on your launches if you want to get your times down. You should be able to get into the high 13s without much trouble with your mods.
Old Jun 27, 2007 | 12:36 PM
Acidangel_5.0's Avatar
drop you 60' R/T is just for show..
rule of thumb... every .1 you take off your 60' will equate to .2 off your 1/4 time...
your easily a mid 13 sec car but you just need the driver mod
Old Jun 27, 2007 | 12:44 PM
RaineMan's Avatar
Okay... if you wanna lower your times... lose that weight.
Ditch the wife... ditch the jack and spare out of the back... pull out the rear seats. That'll save you 200lbs or so. (Not saying the wife is that heavy, just a guess) LOL
Now to help with traction... lower your tire pressure to say 25PSI... it'll help you hook.
Just watch launching too hard... you can snap the stock axles with the mods you are running.
Old Jun 27, 2007 | 01:47 PM
FryLoch's Avatar
Just work on shifting fast and findind a good rpm to launch at... These really arent the easiest cars to drive...
Old Jun 27, 2007 | 02:25 PM
portergraph's Avatar
OP, did you have a full tank of gas too??? A lot of un-needed weight right there too...
Old Jun 28, 2007 | 01:02 AM
RBC's Avatar
RBC
I don't have the car tuned for the 2.85" pulley and it doesn't seem to be running lean. In fact it is putting a little puff of black smoke at the 7k shift.
The only thing about taking all that stuff out is that I have to drive 100 miles to the track and don't want to chance a flat on a 2 lane mountain road.
I can't find anyone around to tune for me and I don't fully under stand HP Tuners well enough to purchase it. Once I feel confident enough to tune with out blowing something up I will buy it.
100% agree with that.
Well not that the reaction matter much like the others said but my best of the night was a .112 and if I am sleeping it is around .3.
I'm no noowb to racing but this car is kicking my ass.
The wife is about 5'10" 130 pounds so there not much weight. The most I would gain by leaving her out would be a tenth or so. As far as the rest I don't want to dissmantle the car for a tenth or two.
Shifting is no problem, but the right rpm to launch at is the key I just haven't found it yet.
Yea I had 3 1/4 of a tank. I should of thought that through with that a little more.
wow that was a lot of work I think I got every thing.
Old Jul 4, 2007 | 05:58 AM
Shanman's Avatar
feather it at around 2500 if it doesn't bog then u should hook and go ahead and floor it. after i launch and hook, i floor and the tires don't spin as bad most the time u can tell if ur spinning at the end of first by quick shifting into 2nd and if ur RPM's are below 4k then u did a bad job. i know its hard to hear tires spinning when all u can listen to is ur s/c
Old Jul 4, 2007 | 09:04 PM
RBC's Avatar
RBC
I think I am going back this Friday and I am really wanting in the 13's. I am replacing my plugs with the ngk 1 step colder and I hope it will run a little better. We'll see.
Old Jul 5, 2007 | 01:08 PM
rukkee's Avatar
"The only thing about taking all that stuff out is that I have to drive 100 miles to the track and don't want to chance a flat on a 2 lane mountain road."
Take that stuff out at the track , you don't need to leave it at home.
Old Jul 7, 2007 | 06:00 PM
RBC's Avatar
RBC
Well I went back to the track and yielded a little better times but I still could not break into the 13's. I ran 14.0 @ 104 with a 2.4 60' time. The car feels really good and fast, but I could not hook up for ****. My 60' times stayed the same all night but my mph at the beginning of the night was 102 and steadily went up to 104 by the end of the night. I think I will buy a air pump so I can play with tire pressure front and rear. I was thinking around 25 psi for the front and 45-50 psi for the rear. Any more suggestions?
Old Jul 7, 2007 | 06:24 PM
DressBoyBlues's Avatar
ya if you still have wheel hop go with a ingalls stiffy shock, other than that your doing really good for what you have if you have the money get 60lbs injectors, oversized tensioner just to make sure its not slipping and a hptune. but all and all great numbers!
Old Jul 7, 2007 | 06:29 PM
RBC's Avatar
RBC
The ingalls will not work with the TTR mount. I believe my next mods will be the CAB's and maybe a strut tower brace. The car should be mid to high 13's with the mods that I have. I think with a few more adjustment I will be there.
