Plug Gapping
Old May 29, 2006 | 04:28 PM
hondaeater's Avatar
Plug Gapping
Does plug gapping really make a heck of a difference?
I got the 1 step colder plugs with the stage 5 SC, but the dealer didnt bother to gap them to .035, and left them at *I think* .040
Would that .005 make that much more difference?
Old May 29, 2006 | 06:56 PM
AlphaJaguar5's Avatar
Yes it does
Old May 29, 2006 | 09:14 PM
hondaeater's Avatar
ty vm
Old May 29, 2006 | 11:16 PM
sscobalt06's Avatar
I have mine gaped at .045 with the stage 3, is that to high?
Old May 29, 2006 | 11:25 PM
distillion's Avatar
that what i have mine at with my stage 2, with ngkbkr7e's
MarcS's Avatar
The Stig
Autolite® Copper Core Spark Plugs feature a copper core center electrode sheathed in high chromium-nickel alloy for superior heat dissipation and durability. The longer insulator nose provides a longer path to control fouling deposits, and the mixture of nickel and copper-glass seal bonds the insulator, terminal post and center electrode together, assuring full voltage. In addition, the chromium-nickel alloy ground electrode resists gap erosion.
The stock spark plugs for the LSJ motor are NGK PFR6T-10G platinum plugs. Platinum and iridium plugs are much harder and more expensive metals that can last up to 100,000 miles however they are not the best metal for heat dissipation. In our experience copper based plugs are far superior in supercharged applications and while they may not last as long as platinum or iridium plugs they will offer better performance. In addition to being copper based these plugs are also one heat range cooler than stock which helps reduce the possibily of detonation and the resulting knock retard.
New spark plugs should always be gapped prior to installation. The stock LSJ spark plug gap setting is .045", and that works fine for the lower boost settings. As the boost increase, smaller plug gaps are required to prevent spark blow-out. Following are our dyno-proven LSJ spark plug gap recommendations:
Stage 1 - 3.30" to 3.20" supercharger pulley - .045" gap
Stage 2 - 3.10" to 3.00" supercharger pulley - .045" gap
Stage 3 - 2.90" to 2.80" supercharger pulley - .040" gap
Stage 4 - 2.70" to 2.60" supercharger pulley - .035" gap
Stage 5 - 2.50" supercharger pulley - .035" gap
- www.intense-racing.com
Old May 30, 2006 | 10:09 AM
sscobalt06's Avatar
Originally Posted by MarcS
Thanks for the info.
Old May 30, 2006 | 10:50 AM
player_1's Avatar
so when I get pullies ( 2.8, and a 3.1 ) what should I gap my plugs to?
Old May 30, 2006 | 10:52 AM
budman128's Avatar
What about irridium they say you are not supposed to gap
Old May 30, 2006 | 10:58 AM
Matty's Avatar
I have mine at .037 now and when I get the GM stage2 and 2.8 pulley put on, I have the BRK7E's ready to go in and am going to go with .037 again. JMO.
Old May 30, 2006 | 11:04 AM
distillion's Avatar
my BRK7E's are at .045 right now, when i get my 2.85 pulley ill see how it reacts, i hear anywhere from .035 to .045 is what people are doin, would i be better to gap them at .40 with a 2.85 pulley?
Old May 30, 2006 | 11:14 AM
Matty's Avatar
That is what Intense is recommending.
Personally I am going to go a tad smaller.
Old May 30, 2006 | 11:57 AM
CTCOBALTSSS's Avatar
My NGK's are gapped at .38
.35 is the most power but least reliable.
.40 is the least power but most reliable.
This is for GM Stage 2 at least.
Any pulley that is smaller than 3", I have no idea.
Old May 30, 2006 | 12:55 PM
WJT DEMON's Avatar
Thats inaccurate. Stock setting is .035. Well it is on mine anyways. So then are the recommendations inaccurate as well?
Old May 30, 2006 | 01:01 PM
distillion's Avatar
i cant remember who it is on here but hes got some mods, a smalelr pulley and a tune and the best hes seen when it comes to gapping is.045
Old May 30, 2006 | 01:03 PM
distillion's Avatar
my stock plugs were closer to .040, and some were .038
if you start buliding alot of boost and power you dont want it to tight.
im gona see how my 0.45 gap works on a 2.85 pulley.
Old May 30, 2006 | 03:35 PM
The actual stock gap is SUPPOSED to be .039" its in your owners manual towards the back. Although new service documents state a .040" gap
Old May 30, 2006 | 03:54 PM
skoshi130's Avatar
What do you guys have for stock plugs
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
