which plugs
Old May 12, 2008 | 02:26 PM
jwolf8604's Avatar
which plugs
So which plugs for my mods? step 2 NGK from zzp????
Bump, are the plugs from zzp the ones I should get?
Old May 12, 2008 | 03:00 PM
06_SS_S/C's Avatar
Bkr7e
Old May 12, 2008 | 03:01 PM
BOOSSTED 06's Avatar
you should be fine with the bkr7e lik 06 said
Old May 12, 2008 | 07:47 PM
cobalt ss/sc's Avatar
autolite 3922 is what I use.
Old May 14, 2008 | 11:13 PM
jwolf8604's Avatar
Bump, are these the right plugs??????
http://cgi.ebay.com/ebaymotors/New-N...spagenameZWDVW
Old May 15, 2008 | 01:10 PM
jwolf8604's Avatar
bump, correct plugs?
Want these plugs, but the -11 at the end of the product number is scaring me to buy, please inform me!
Old May 15, 2008 | 01:11 PM
DoubleLP's Avatar
Go to NAPA or an auto store to buy them. A lot cheaper and easier to get them.
Old May 15, 2008 | 01:20 PM
06_SS_S/C's Avatar
Yeah, i would just go to the local auto parts store, but the stock number 6097 like it shows on the box is correct.
So no, the BKR7E-11 are not the right plug, they have a different stock number than the BKR7E
Old May 15, 2008 | 01:42 PM
n8g's Avatar
n8g
Spend $8 at the local parts store.
Old May 15, 2008 | 01:48 PM
jwolf8604's Avatar
checked advanced auto parts and o'reillys ....neither had this plug
Old May 15, 2008 | 01:50 PM
chevysssc's Avatar
i got zex plugs just go to their site or call summit they have never steered me wrong (1-800-230-3030)
Old May 16, 2008 | 01:14 PM
jwolf8604's Avatar
Ive seen the NGK plugs recommended the most...its frustrating that I can't find any Somebody reccommend where to find them
Old May 16, 2008 | 01:20 PM
06_SS_S/C's Avatar
Overpriced, but http://www.sparkplugs.com/results_cr...KR7E&x=47&y=13
Old May 16, 2008 | 01:23 PM
rnjmur's Avatar
The -11 at the end only specifies a different gap size. BKR7E-11 plugs come gapped from the factory at .044" and the BKR7E come gapped at .025" (I think .025"... maybe .032") from the factory.
and yeah sparkplugs dot com have pretty much the best deals on plugs if you can't find them locally.
Old May 16, 2008 | 01:26 PM
M-Dub's Avatar
Ummm, NO! The numbers at the end reflect the heat range of the plug....
O'Reilly's carries these plugs that is where I buy mine... they are like 1.25 or something each!
Old May 16, 2008 | 03:38 PM
INFE's Avatar
i went with the BKR7EIX-11
Old May 16, 2008 | 03:52 PM
rnjmur's Avatar
If you don't know then don't post false information.
Just so you know, a break down of the NGK plug:
B - Thread size (14mm)
K - Hex size (5/8")
R - Plug construction (Resistor type)
7 - Heat range (higher numbers are colder)
E - Thread reach (19mm or 3/4")
- (optional)
11 - Extra wide gap (1.1mm gap or .044" gap)
There is also additional optional features that can denote special plug designs as well as additional options that can go behind the Thread reach to denote special plug designes i.e., BKR7EIX-11 is the same plug but has an iridium tip instead of copper.
If you go with the iridium becareful, if you bump the tip while gapping them you will break the tip off. I always buy the BKR7EIX-11 plugs because it is easier to close a gap then to make it wider.
Old May 16, 2008 | 09:27 PM
Johnny B's Avatar
^^^ i think jason knows what he's talking about.
m-dub is owned....
Old May 18, 2008 | 10:58 AM
rukkee's Avatar
Mdub made a simple mistake , usually the last number is the heat range , but not when dealing with dash numbers IE -11
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
