PLX wideband install, narrowband question
Old Apr 21, 2007 | 01:58 AM
Rodimus_Prime's Avatar
ok so i put my wideband back in the car and im using the wideband to send the 5v signal to my gauge and the 1v narrowband to the stock pcm, it does have 2 outputs so that you can use a single sensor to provide both
My problem is the ground wire, there are 4 wires on the o2 sensor, the two white are fine thats the heater circuit i have that taken care of with a resistor, the gray is the signal wire, i have the narrowband signal here and thats all good
now on the o2 sensor there is a black wire, can i ground my wideband to this?
heres a pic of the control box i made which holds the resistors
Old Apr 21, 2007 | 12:09 PM
zomghax's Avatar
http://www.plxdevices.com/AppNotes/PLXApp004.pdf
Maybe that will help you
Old Apr 21, 2007 | 04:43 PM
Johnboy12358's Avatar
Rodimus, you doing projects at hotels?
Old Apr 21, 2007 | 04:54 PM
The table makes an excellent work bench
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
n20saturn
Sep 30, 2015 12:26 AM
Bohb
Sep 27, 2015 09:11 PM
