polishing the blower
Old Sep 23, 2006 | 12:40 PM
selfinfliction's Avatar
i'm pulling off the blower in about an hour so i can polish it, i'll let everyone know how long it takes and any trouble spots, etc...
i'm doing it myself cause it's not worth paying $300+ to have steig or someone else polish it.
Old Sep 23, 2006 | 12:43 PM
06blackg85ss's Avatar
good luck man... I watched them polish badg1rls.... its a PITA.... but it looks awesome and is definatly worth the work... I"ll be doing mine soon too along with the valve cover and the fel rail... **** looks sweet
SS_SC_Cobalt's Avatar
good luck
IMHO tho it is well worth it to have someone else polish it, after seeing mine I can definitely agree, there is a lot of material to remove to get it like a mirror
Old Sep 23, 2006 | 12:49 PM
yeah i seen the valve cover along with the blower and it looked good, after seeing hers early this week, i decided to start with the blower since it will probably be the worst. i threw some 150g on a couple of spots and the blower metal was softer than other stuff i've polished before, so i don't think i will have any problems with the low speed dremel and a bunch of different grit tips
Old Sep 23, 2006 | 12:53 PM
shouldn't be a problem... dremel is the best way to go with all the little corners... thats what I plan on using...
Old Sep 23, 2006 | 01:07 PM
BlilBT's Avatar
Biggest Problem with the Supercharger is that LiL Dimples in the Metal or Pits >> what ever you want to call it are very deep in areas so getting them all out is a Challenge!
The Buffing & Polishing are the easiest unless you dont have the wheels! Drimmel & Sanding wont do it alone!
Word to the wise!
Old Sep 23, 2006 | 01:14 PM
Word to the wise!
i don't use polishing wheels, i always do that by hand, near the final stages you will see that finishing it by hand works 10 times better,. it takes much longer, but i'm not in a hurry
i was thinking about throwing a 3m disk on a drill somehow and using it, but we only have 80 grit disks so it would work only for the initial deburring
Old Sep 23, 2006 | 01:22 PM
BlilBT's Avatar
No the Wheels are for the shine will never get it to a mirror By hand >>> Check out eastwood.com they have some small 3 inch Polishing & Buffing wheels! You need a sewn Cloth wheel & a Loose cloth wheel white Rouge & some Tipoli>>> Swen Cloth & Tipoli ...Then Loose Cloth & White Rouge!
Alll My sanding was done by hand! Besides the Calipers I used a Die Grinder!
Old Sep 23, 2006 | 03:19 PM
ummm you got some money you would like to put on it? cause i got a picture of my old r6 here that is so damn shiney you can see your reflection in the frame a few feet away, and all i did was the sandpaper-steel wool-hand polish method
anyways, you'll see a pic of the blower tomorrow.
Old Sep 23, 2006 | 04:48 PM
l guess this is temporarily halted. damn dremel burnt up, and i'm sure as hell not hand sanding this lol. guess i'll have to wait until i get a new one to start again, until then i'll be rolling around with a blower that's had about 25% of it ran over with some 60 grit, and the rest is normal lol
Oct 20, 2015 09:56 PM
Silverbullet333
Oct 4, 2015 02:27 PM
cavfiredesire
Oct 3, 2015 08:02 PM
jimbofug007
Oct 2, 2015 12:06 PM
goaliemo
Sep 28, 2015 01:37 PM
