Popped out of 5th gear
Old Jul 13, 2009 | 02:10 PM
cgrammer's Avatar
So, while on our way to our weekend getaway Friday, transmission popped out of 5th gear. Any idea why it did this? First time it's ever happened. Never did it before 100,000 miles.
Here's what happened:
We were driving about 60mph and let off the accelerator going through a curve with a grandma in front of us. She got into the left lane and we hit the accelerator to pass... not hard or anything, just normal acceleration. As soon as I put my foot on the accelerator, the shifter popped down out of 5th and of course the RPMs went up since it was in neutral. I shifted into 5th again and it didn't do it the rest of the trip.
Now, this morning, it was a phenomenal frog strangler. I mean, I couldn't go faster than 50mph on the interstate because of the downfall. Anyway, I get off the interstate onto a county road on the way to work and I shift from a stop, 1st to 2nd, and it totally boggs down and crap. It does it one more time from 3rd to 4th later down the road (like 15 minutes later). I'm pretty sure it was water getting into the air filter on my RAW CAI. Before you ask, I didn't get a dang hydroshield. It didn't do that going to/from lunch a little bit ago. I notice no difference in power/acceleration/RPMs now. Y'all think that's what happened? Maybe a little water in the filter? If so, is that totally bad or just something to overlook for now?
Any help/advice is mucho appreciated
Old Jul 13, 2009 | 02:13 PM
didnt do it before 100,000 miles?! how many miles are on your car?
Old Jul 13, 2009 | 02:14 PM
cgrammer's Avatar
103k now.
Old Jul 13, 2009 | 02:15 PM
BYT*SS*TURBO's Avatar
I hate when that happens....JUST out of warranty thanks...
GL!!
Is it possible you just didn't sync it all the way in?
Old Jul 13, 2009 | 02:17 PM
cgrammer's Avatar
GL!!
Nah, we had been driving in 5th for about 6 miles until that point. I think I know how to drive a stick, TYVM
Old Jul 13, 2009 | 02:22 PM
just got a dirty thought from that...... lol.
Old Jul 13, 2009 | 02:24 PM
wantedSS/TC's Avatar
synchros 9/10 times, my honda used to pop out of 3rd gear all the time, replaced under warranty though
Old Jul 13, 2009 | 02:25 PM
cgrammer's Avatar
LMAO! Please don't change the subject! At least wait until I get an answer then this thread is yours to jack, my friend!
Figured you had a Honda...
This is the first time it's happened. And of course right after Powertrain expires POS.
I'm actually being helpful here!
Suck my *****!
Last edited by wantedSS/TC; Jul 13, 2009 at 02:25 PM. Reason: Automerged Doublepost
Old Jul 13, 2009 | 02:26 PM
cgrammer's Avatar
Grow a pair, darling
Old Jul 13, 2009 | 02:27 PM
you're turning your thread into garbage!
lightningfast5's Avatar
Suck my *****!
come on now lets be nice here.
Old Jul 13, 2009 | 02:28 PM
cgrammer's Avatar
U started it when you said "Honda"
/threadjacking
Where are my answers?
We were being PG-13 there
Old Jul 13, 2009 | 02:29 PM
/threadjacking
YOU ALREADY HAD IT!!!!!!!
it's your synchros!! seriously!
Old Jul 13, 2009 | 02:30 PM
cgrammer's Avatar
WTF IS SYNCHROS?!?!?! I'm a car no0b, Matt!
& does that explain the engine garble this morning, too?
Old Jul 13, 2009 | 02:31 PM
/threadjacking
yeah it was PG-13 but i could see it quickly going to R and then were right next to be X rated trannys
Old Jul 13, 2009 | 02:33 PM
I wasn't insulting your driving. And you didn't stay how long you were already in 5th
After re-reading tho..You did say you were driving along and went to accel, so you must've been in 5th cruising. Sorry
If the teeth, the so-called dog teeth, make contact with the gear, but the two parts are spinning at different speeds, the teeth will fail to engage and a loud grinding sound will be heard as they clatter together. For this reason, a modern dog clutch in an automobile has a synchronizer mechanism or synchromesh, which consists of a cone clutch and blocking ring. Before the teeth can engage, the cone clutch engages first which brings the selector and gear to the same speed using friction. Moreover, until synchronization occurs, the teeth are prevented from making contact, because further motion of the selector is prevented by a blocker (or "baulk") ring. When synchronization occurs, friction on the blocker ring is relieved and it twists slightly, bringing into alignment certain grooves and notches that allow further passage of the selector which brings the teeth together. Of course, the exact design of the synchronizer varies from manufacturer to manufacturer.
The synchronizer has to change the momentum of the entire input shaft and clutch disk. Additionally, it can be abused by exposure to the momentum and power of the engine itself, which is what happens when attempts are made to select a gear without fully disengaging the clutch. This causes extra wear on the rings and sleeves, reducing their service life. When an experimenting driver tries to "match the revs" on a synchronized transmission and force it into gear without using the clutch, the synchronizer will make up for any discrepancy in RPM. The success in engaging the gear without clutching can deceive the driver into thinking that the RPM of the layshaft and transmission were actually exactly matched. Nevertheless, approximate "rev-matching" with clutching can decrease the general delta between layshaft and transmission and decrease synchro wear.
To dumb it down a little
They basically keep your gear, in gear. If they are worn it will pop out like yours is.
/ thread
Old Jul 13, 2009 | 02:34 PM
the syncros deal with the tranny dont know a lot about that so sorry but this morning issues is probably cause the filter got wet, did it through any codes or just bog down
Old Jul 13, 2009 | 02:35 PM
cgrammer's Avatar
Not a problem! I was just messin' w/u!
/ thread
Has nothing to do with my engine garble.
Nope, no codes... just boggled for a sec.
I didn't see that Ms. Demanding .... I need more details (e.g. - when starting up, idling, driving, coasting)
Old Jul 13, 2009 | 02:39 PM
Staged07SS's Avatar
Administrator
Administrator
deff get a hydroshield for your intakes air filter. it not only keeps the filter from getting wet, but actutally protects the filter from all the grime and **** that gets in the inner fender well. The bogging was prob. due to a wet filter and the shifter popping out was most likely your syncros. 100,000+ miles on the stock tranny would do that.
cgrammer's Avatar
5 points to this awesome member.
/thread
Old Jul 13, 2009 | 02:41 PM
Staged07SS's Avatar
Administrator
Administrator
/thread
thank you dear .... glad i could help
Killa702's Avatar
nice
