Ported Head Question
Old Sep 24, 2006 | 03:22 AM
Manny13's Avatar
Exclamation Ported Head Question I Need Help?
How does the ported head sold on crateenginedepot.com http://(www.crateenginedepot.com/sto...-P333C144.aspx) compare to the work the JBP does? What type of gains can I expect from the the Ecotec perfrmance Head on CED's site. Will I need different internals?
Old Sep 24, 2006 | 03:29 AM
Allshot's Avatar
I think the gmp one you get 4 hp and the cti has yet to be dynoed. Id think the cti would yield a better gain though
Old Sep 24, 2006 | 03:34 AM
cobalt06ss_sc's Avatar
i would tend to agree the GMP one is probably just cast with larger ports and combustion chambers while the other is probably portes and the ridges are smoothed out so it decreases turbulance. if the prices are close i think i would probably got the the non GM head. the big thing you want to look at is how many CFM's it flows. the more the better.
Old Sep 24, 2006 | 03:59 AM
Manny13's Avatar
I've had my cobalt for almost two years now and have done many custom mods but have been conservative until now with performance gains for the sake of waiting to see what is out there. However, I'm beginning to build my engine and want to do everything at once. I currently own all these following products but am holding off to do it as one big eventful install: intake, header,3" downpipe, 3" exhaust, modular pulley system with a 2.7 pulley, 60lb injectors and harness, 2 step colder plugs, adjustable pulley tensioner and CA Heat exchanger on order. I have another 2500 - 3,000 to spend and was considering pistons, ported head, cams, and valve springs but don't know which to get and from where? Please I need advice! My goal is 300 WHP somewhat safely!
Old Sep 24, 2006 | 04:03 AM
Allshot's Avatar
Get the meth injection. Im waiting for my cobalt addiction h/e also.
Old Sep 24, 2006 | 04:18 AM
Manny13's Avatar
where is a good place to get my pistons? I'm thinking 10.0:1 and how about cams
Old Sep 24, 2006 | 04:19 AM
Manny13's Avatar
how much power can our stock head gasket handle?
Old Sep 24, 2006 | 04:21 AM
Allshot's Avatar
Intense sells the pistons. I know the pistons handle 300 Hp so the gaskets hould surpass those numbers.
Old Sep 24, 2006 | 04:23 AM
Allshot's Avatar
I dont know if anyone sells cams yet but if they did it would be Jbodyperformance. They wont be cheap though
Old Sep 24, 2006 | 08:10 AM
05sedan's Avatar
the ss s/c pistons hold more than 300hp....the 2.2 pistons handle that much.....
Old Sep 24, 2006 | 08:17 AM
g5mike's Avatar
Ditto
Old Sep 24, 2006 | 08:42 AM
StinkBOMB's Avatar
These engines in these cars are good up to at least 300hp, what you have to watch out for is the drivetrain. Clutches, axles and entire transmissions in some cases.
Old Sep 24, 2006 | 09:28 AM
CbYellowSS's Avatar
3 things
intense pistons
jpb cams
and jpb head 3 different choices for the head last is about 3k but gives a 14-19 percent gain in hp
Old Sep 24, 2006 | 09:42 AM
patathSS's Avatar
The headgasket is the weak link in the equation. You need to go to studs and a different headgasket if you want to push that much power.
Old Sep 24, 2006 | 09:49 AM
SS_SC_Cobalt's Avatar
That head is fully CNC ported, meaning GM made a program and used a computer to open up the ports as much as they could, and CNC is smooth, much better than hand porting unless you are one of those exceptional few that can do better freehand.
Might want to ask Tom if he has a copy of the flow sheet, I have been considering this, but I was hoping for a head that accepts little larger valves
also we have a differnt head than most ecotecs, so I am not sure which one is cnc'd
this is an interesting link for info on the ecotec http://www.tprmag.com/inside/ecotec/powertrain.shtml
Old Sep 24, 2006 | 01:29 PM
NJHK's Avatar
If you're adding a bunch of boost on top of 10.0:1 compression, you better have good computer management to help prevent knocking. Invest in HP Tuners.
Pistons? Wiseco all the way. Go to www.carcustoms.net, contact karo and he'll set you up.
Cams? jbodyperformance.com should have a set for your motor.
One other thing, you're in Cali, wouldn't this get you in a shitload of trouble emission wise? Just curious.
Old Sep 24, 2006 | 01:37 PM
patathSS's Avatar
I just realized you were talking about headers and he is talking about heads. BIG difference
Old Sep 24, 2006 | 01:55 PM
glockglade's Avatar
They have to be more than that the pistons in the 2.2 ecotech are good for around 280whp.
Old Sep 24, 2006 | 05:30 PM
Manny13's Avatar
i don't have to worry about emissions for the first seven years in cali. Are JBP the only Cams for our cars? I want to try the 10.0:1 compression and go with as small of a pulley that will allow for no engine knock. How about the drivetrain? what needs to be beefed up?
Old Sep 24, 2006 | 05:41 PM
NJHK's Avatar
Yeah I understand that but cops can still pull you over and make you go for an emissions check and say that parts you have under the hood are illegal...atleast that's what the training video I saw was saying.
Old Sep 25, 2006 | 02:25 AM
Manny13's Avatar
very true! does anyone think 10.1:1 compression is too high if I do the mods above?
Old Sep 25, 2006 | 05:15 AM
NJHK's Avatar
If you can get your hands on HP Tuners, it's not bad. Ideally, people try and stay away from being closer to detonation situations, that's why they lower their compression instead of raising it like you are (stock you're at 9.5:1).
Ultimately, it's up to you.
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
