Ported heads and cams
Old 06-12-2013, 05:44 PM
mrbelvedere's Avatar
Originally Posted by all_motor_mike
can u be more specific......
cause heres the numbers from my race l61 head...... where my race lsj was the same profile with slightly bigger exhaust ports so i said it was probably about 5cfm more or so. so where do i not have proof beside the 5 cfm guesstimate i made on the exhaust side?
intake......
.050"- 68.1cfm
.100"- 107.4 cfm
.150"- 143.3 cfm
.200"- 186.4 cfm
.250"- 226.1 cfm
.300"- 251.7 cfm
.350"- 273.3 cfm
.400"- 284.1 cfm
.450"- 293.0 cfm
.500"- 299.1 cfm
exhaust......... percentage of exhaust to intake at given lifts.......
.050"- 53.0 cfm 77.8%
.100"- 88.4 cfm 82.3%
.150"-124.0 cfm 86.5%
.200"- 154.4 cfm 82.8%
.250"- 175.2 cfm 77.5%
.300"- 189.7 cfm 75.4%
.350"- 198.1 cfm 72.5%
.400"- 202.5 cfm 71.3%
.450"- 205.8 cfm 70.2%
.500"- 208.2 cfm 69.6%
OP u get a professionally ported head if i do the work. read up on me before u jump on a band wagon and put me down by saying it wouldnt be done properly.
and lets not forget what that l61 head went on, the stock block recorder holder mr. B......
AMMFAB shop cavi engine rebuild
the goal has been met......... 519whp from the shop cavi
mike
im not ragging on you mike you do good work but you never shown what your lsj head flowed just a guestiment is what you said in the thread a l61 head is different then lsj
https://www.cobaltss.net/forums/2-0l...cation-237952/
Old 06-12-2013, 05:55 PM
all_motor_mike's Avatar
B, they are the same exact ports, i just used an lsj gasket to match the lsj head to instead of a oval l61 gasket.... those are the sme port profile and they are 300cfm intake ports and 210cfm exahust ports to say the least. ive been doing this for 10 years almost now i have a very steady hand sir.
lsj...
l61...
lsj...
l61...
mike
Old 06-12-2013, 08:23 PM
FF_ace's Avatar
Looks good mike
Old 06-12-2013, 08:31 PM
nhanson's Avatar
LSJION just got my head for porting! Looking forward to it...he definitely seems professional.
Old 06-12-2013, 10:14 PM
Originally Posted by FF_ace
Looks good mike
Thank u, its to bad I wasnt able to get ur lnf head done.
Mike
Old 06-12-2013, 10:36 PM
lsjion's Avatar
Nick, you can look forward to some more pictures tomorrow.
Finally got some cleanup done. I didn't realize your car is auto! I'm excited to see this head done on what you're putting together.
Old 06-12-2013, 10:39 PM
nhanson's Avatar
Should be fun!
I was 2.8 pulley seeing 13 lbs with ported M62
Once build is done ill be 2.7 so interested to see where it puts my airflow.
Old 06-13-2013, 08:51 AM
TStone's Avatar
Originally Posted by nhanson
Should be fun!
Lame :P Josh's work will really open up them ports, you need to go 2.6 :p
Old 06-13-2013, 09:19 AM
FF_ace's Avatar
Mike
Ya me too... the other guy i sent it to be ported took it and disappeared
Old 06-13-2013, 10:40 AM
nhanson's Avatar
Judging by where my exhaust marks were on the head, theres a lot to remove!
Old 06-13-2013, 11:16 AM
  #36
l61 lap have a bigger exh port
Old 06-27-2013, 11:13 AM
  #37
LopsidedJester's Avatar
i got the stage 1 ported head from ZZP, i mainly got them to do the head for the valve spring upgrades for high RPMS, but it does seem to open up some and pull a little stronger than before above 3500 rpm. I only have a 2.8" pulley, e85, and stock cams so i think cams will really open it the rest of the way up top.
I feel a bit of a loss down low, but I have long tube headers and a 3" exhaust so i can't move as much air as i need for how open it is. Cams and head are definitely an upgrade for someone moving lots of air, probably show better gains with TVS or Turbo (or M62 if you're running smaller pulley's but you can only go so small and run out off efficiency range).
Old 06-27-2013, 12:05 PM
  #38
TStone's Avatar
That is all common sense. You're opening up the port so there's less restriction. You're not "filling" the ex ports with enough air in the lower Rpms so you'll notice it's a little more sluggish in the lower rpm.
Old 06-27-2013, 01:23 PM
  #39
exactly, some people don't have common sense and want a ported head and cams on a stage 2 kit, and that just isn't gonna make a lot of gain.
Old 06-27-2013, 01:53 PM
  #40
Rent me! per hour
Area47's Avatar
ports on the lsj head aren't even.
jussayn
Old 06-27-2013, 02:54 PM
  #41
mongorat427's Avatar
I noticed a nice bump in power from my COMP Cams/ZZP S1 cams. I run an H62 blower. Not sure how they would be with the M62.
An exhaust ported head is one of the best mods you can do for our cars.
Listen to Mrb though. He has some nice custom ground cams.
Pics of the H62 ? Never saw one
Old 06-27-2013, 11:04 PM
  #42
OttawaMark's Avatar
Lol, sounds like Euthanasia.
Old 06-27-2013, 11:08 PM
  #43
FF_ace's Avatar
no it was scott grimes at sgm tuning in PA... euthanasia did a great job on my IM
Old 06-27-2013, 11:27 PM
  #44
OttawaMark's Avatar
Euth did a great job on my head, but that is so last year and he lost a ton of business due to some fallings out with people and so many blown deadlines. Thought that might have been you too. Still waiting on my MP-90 kit there Euth, 6 months late and at least a dozen excuses!
Old 06-28-2013, 07:16 AM
  #45
Administrator
Administrator
Staged07SS's Avatar
PM with pics of the blower sent
Old 08-22-2013, 04:49 PM
  #46
bLu04dd's Avatar
So you guys are obviously the best crowd to ask this then...
Im about to drop a completely stock LSJ into my 04 cavalier.
I have a steigmeir ported M62, 2.8" pulley, and a bunch of other cooling mods with the LSJ pacesetter header and 2.5" exhaust (larger header, 1 3/4" or 1 7/8" i believe).
While I have the engine out of the car, is it worth at least doing a port job on the exhaust side, or would i be best to wait until i plan on doing a cam upgrade down the road? I already have the ZZP springs with stock cams.
And remember, its already out. So any labor spent over a few cold beers and a few hours of work is worth it if its done prior to going in, nothing needs to be removed to do it.
Thanks!
Old 08-22-2013, 05:31 PM
  #47
yea its worth it pm lsjion
Old 08-22-2013, 05:40 PM
  #48
I forgot lsjion has my head lol i gotta start saving up to pay him
Old 08-22-2013, 06:56 PM
  #49
bLu04dd's Avatar
do you guys know what it typically runs cost-wise on avg, shipping included? I was thinking of doing it myself and just being more conservative on the port. Im not looking for 400hp...just trying to make it as efficient as possible on my mild set up before I put the head back on soon.
Old 08-22-2013, 07:16 PM
  #50
nhanson's Avatar
lulz
Quick Reply: Ported heads and cams
