Porting the head...
Old Dec 2, 2009 | 03:43 AM
JAYNO20's Avatar
Porting the head...
Whats involved in doing this?
Old Dec 2, 2009 | 03:49 AM
CordiaDOHC's Avatar
Not doing it while its bolted to the block!
Old Dec 2, 2009 | 05:02 AM
JAYNO20's Avatar
uhhh...
Old Dec 2, 2009 | 06:56 AM
More_Torque_More_HP's Avatar
Originally Posted by JAYNO20
uhhh...
Porting the head involves grinding and polishing the intake and exhaust ports to increase flow through the port. The LSJ responds better to exhaust porting than it does to inlet porting.
You need to remove the head from the engine and disassemble the head. The object is to shape the port for better air flow and polish to port to minimize the "wall affect".
After the porting the head needs to be washed extremely well to keep from getting the ginding dust into your engine and destroying the bearings, crank and rods.
Old Dec 2, 2009 | 07:40 AM
selfinfliction's Avatar
taking off your head and dropping it off at a good machinist and paying the bill.
i think these cnc heads are a complete waste of money. $1000+ for a p&p job when you can get a damn good p&p job by hand for $500-$600. everything flowed and matched etc...
Old Dec 2, 2009 | 10:16 AM
insylem's Avatar
It sounds like youd need new valves after this to compensate for the increased size in hole? Larger valves wont fit the indentations in the pistons either, so would diffrent pistens or reworked pistens be needed as well?
And even if you didn't need new valves, youd at least need to relap them...
Old Dec 2, 2009 | 12:14 PM
you can add oversized valves, but a P&P doesn't dog the material from around the valve seat. if you go with oversized valves, plan to spend an additional $100-$200 for machine work to properly fit those, that is why most people stick with no valve work on a P&P
Old Dec 4, 2009 | 02:21 AM
JAYNO20's Avatar
So I assume swapping the head is probably not an easy process?
Old Dec 4, 2009 | 02:24 AM
Darkmanx's Avatar
just 2 bolts
Old Dec 4, 2009 | 02:29 AM
JAYNO20's Avatar
Originally Posted by Darkmanx
just 2 bolts
I doubt this..., seriously, how hard is it?
Old Dec 4, 2009 | 06:51 AM
alldata says 8-10 hours of labor for the dealership to do it
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
