possible leak?
possible leak?
i keep noticing im getting what seems like a clear oil almost comming off the drive belt. i have no idea if its something leaking, or just road grime. i've checked all hoses and lines and nothing seems to be leaking, the only other thing i could think of is the hydralic tensioner, but was doubting it being the problem . has anyone else had this problem? or am i just getting parinoid over road grime?
Is it humid? are you getting the dreaded screeching of the drive belts? Have you checked you fluid levels, then waited a little while and checked again to see if any changed noticeably? these would be the first things that I would look into
n20saturn
Sep 30, 2015 12:26 AM
