possible leak?
Old Jan 10, 2007 | 02:45 AM
alpollon's Avatar
possible leak?
i keep noticing im getting what seems like a clear oil almost comming off the drive belt. i have no idea if its something leaking, or just road grime. i've checked all hoses and lines and nothing seems to be leaking, the only other thing i could think of is the hydralic tensioner, but was doubting it being the problem . has anyone else had this problem? or am i just getting parinoid over road grime?
Old Jan 10, 2007 | 08:49 AM
Johnboy12358's Avatar
Is it humid? are you getting the dreaded screeching of the drive belts? Have you checked you fluid levels, then waited a little while and checked again to see if any changed noticeably? these would be the first things that I would look into
Old Jan 10, 2007 | 08:57 AM
3fo893013L's Avatar
My 94 Z24 did that, put a plastic skirt underneath it the oil pan. That will fix it.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
