Power/boost after ZZP??
Old May 6, 2010 | 02:55 PM
PJ09's Avatar
I have an 07 SS/SC. What kind of numbers should i expect wih Injen CAI, ZZP stage w/ 2.7" pulley, ZZP cattd headers/downpipe combo, custom 3" exhaust. Just wondering if anyone is running anything similar or if anyone has an idea. Thanks.
Old May 6, 2010 | 02:58 PM
jonathan923's Avatar
stage what? or what injectors will u be running? and it all mostly depends on the tune...
Old May 6, 2010 | 03:01 PM
skatin_boarding's Avatar
I personally wouldnt go with a 2.7 unless you have meth or e85.
Old May 7, 2010 | 12:40 AM
PJ09's Avatar
sorry stage 3. i thought i put it. its
2.7" pulley
60 lb injectors
GM stage 2 belt
NGK 4644 spark plugs gapped at .035
ZZP S3 heat exchanger
ZZP pcm
3" downpipe to 3" exhaust(idk whether to go with the cat'd or not)
and injen cai.
Also im new to the tuning scene, i wanna learn more. But someone told me i couldnt tune without getting a new ECU or getting the codes to unlock it from GM.
Thanks for the help
oh and also i think im gonna get the dual pass.
Old May 7, 2010 | 12:56 AM
Pyros777's Avatar
Dual pass and that heat exchanger wont save you from the 2.7. You'll be seeing 160+ IAT2s (temperature after the supercharger) easily. Definitely get meth or e-85 or reconsider going with a larger pulley. You'd be surprised how much you can get out of a 2.9".
You can definitely tune using your stock ECU, no need for any codes from GM. All you need is access to HP Tuners or Trifecta*.
*Only Trifecta offers the GM Stage 3 OS with the customizable high octane mode, user-adjustable rev limit, nitrous algorithm, and unlocked A/C.
Old May 7, 2010 | 09:15 AM
^^^Listen to this guy.
Old May 7, 2010 | 09:44 AM
freakta's Avatar
more cooling mods and youll be happy
Old May 7, 2010 | 10:02 AM
its a good setup and defenately u need more cooling mods but theres no need to go 2.7 when there are setups making more power runnin on 2.9 pulleys. and its safer for ur supercharger too.
Old May 7, 2010 | 10:13 AM
danieluf's Avatar
I have basically that exact setup but I went with a 2.8 pulley and a 2.5 gmpp exhaust. Put down 307 hp on the good ole interceptor. So hopefully something around 260 whp give or take.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
