power difference between gm stage 1 and 2
Old Feb 14, 2007 | 04:01 PM
Johnboy12358's Avatar
I think it comes with closer to 3.1" pulley. I am playing with the idea of moving to the stage 3 pulley myself, which is right at 3.0"
Everything I have heard says that 2.9 should be safe, but monitoring gauges would be a good idea. Definitely if you go down to a 2.8" (in this case, new injectors would be in order)
Old Feb 14, 2007 | 04:33 PM
Pooch's Avatar
is the stage 3 pully only 3"? GM realy needs to step up, i mean if your gona void you warranty, why not make it worth it. So dose anyone have the part number for the 3" pully from the stage 3 kit? and will it fit the stage 2 hub, im guessing it will but i just thought id ask
Old Feb 14, 2007 | 04:45 PM
http://www.crateenginedepot.com/stor...P1749C196.aspx
Yes it fits the GM stage 2 hub.
Old Feb 14, 2007 | 04:51 PM
Psykostevo's Avatar
Originally Posted by brandondrecksage
I was wondering what the power difference is. I've done soem research and it seems most of the power from the stage two kit, on the dyno atleast seems to be made because of the 7k redline. I'm just looking for the best bang for the buck that'll keep my warranty intact. I also don't want to spend to much because once the warranty is up i'm planning a blower swap. Thanks.
Put a Big Fat DGAF on the HP difference, Stage 2 is a Torque Difference!
Originally Posted by Pooch
i may save for a bit longer and get both, but i hear stage 2 is a super rich tune. is this true? and if so would it be smarter to put on a 2.9 pully instead of the 3.0 that comes with stage 2? or is this a bad idea
When you read the tune, it is actually leaned out, not rich by any means.
Last edited by Psykostevo; Feb 14, 2007 at 04:51 PM. Reason: Automerged Doublepost
Old Feb 14, 2007 | 06:21 PM
Pooch's Avatar
Realy? i have read over and over that it is rich. even on guy i know that has it, his car runs rich, you can smell raw fuel in the exhaust and its black in the tail pipe. maybe he got the wrong tune?
but would a 3.0" pully on stage 2 help or hurt the car?
Old Feb 14, 2007 | 06:37 PM
Mike's Avatar
I dont have any idea how a stage two would be without an exhaust, but my guess is it would kick some serious ass anyways.
Stage 2 is totally worth it, the warranty safety net is nice, plus I still net around 22-27mpg (depending on how fast I drive, and hwy/city)
I have Stage 2 without exhaust...see my sig for track times.
Old Feb 14, 2007 | 06:45 PM
Psykostevo's Avatar
It can easily handle the 3.0" Pulley.
If you can smell raw fuel then it is not a good reflash, I would take it back in to have it redone. More than likely the injector flow rate was not calculated properly. There was an updated reflash released in the last couple months.
Old Feb 14, 2007 | 07:32 PM
Pooch's Avatar
cool i think im gona put the stage 2 on and try with the stage 2 pully and then with the stage 3. also i think if i put on the 3.0" pully im gona go with the dual pass just to reduce the IATs.
im gona price out everything this week and see if my tax return will cover it all
Old Feb 15, 2007 | 04:28 AM
Maxim_X's Avatar
Stage 2 comes with a 3.01" pully. I don't know what .01 will do or why you guys are even contemplating it. I belive stage 3 comes with a 2.79 inch.
Old Feb 15, 2007 | 06:50 AM
Matty's Avatar
Stage 2 pulley is 77.9 MM = 3.067"
Stage 3 pulley is 76 MM = 2.992"
For a difference of 0.075"
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
