pro /con's
Old Jul 17, 2005 | 10:35 AM
fifasf's Avatar
Question pro /con's
Ok what are the pro's and con's of doing theses 2 mods which are the mods that I want to do . By pro's I mean hp gains etc. and by con's I mean , blowing up engine , trans etc.
1. Porting and polishing your blower.
2. Smaller puley swap (3.25" to be exact) also with the puleey swap I am still getting mixed reactions ...What will I NEED to get besides the pulley to make sure the engine is fine after putting a smaller pulley on it.
Old Jul 17, 2005 | 10:45 AM
carbombss's Avatar
when i took my blower to machine shop to get pulley setup put on i asked them about porting blower and they said it wont do much for our cars and i have 3.25 pulley swap now and cooler spark plugs and ive had no problems whatsoever so as long as u dont go ne smaller u will b fine
Old Jul 17, 2005 | 12:59 PM
stuffy236's Avatar
well first off, does anyone have pics of the underside of the blower?
second, does anyone know the size of the inlet of the blower?
This is really going to affect whether it would help or not. IF there is a step from the TB to the SC, then yes it will help a little just straightening out that air flow. And if the oulet is not a perfect triangle, then that will also help. Although it usually help a lot till you start dropping to smaller pulleys.
Old Jul 18, 2005 | 08:34 AM
fifasf's Avatar
Carbomb.... Performance specs with the 3.25 ? Did you pay someone to put it on? Did you need a smaller belt? If yes to any how much roughly.
Old Jul 18, 2005 | 08:39 AM
NightmareSS's Avatar
Carbomb - I'm with him any gains ?
Old Jul 18, 2005 | 09:21 AM
carbombss's Avatar
hey guys i diddnt buy puller so i had my local machine shop do it for me charged me 30 to take off factory and put on hub.you CAN reuse factory belt .i picked up 2lbs of boost and my car starts boosts a lot faster then b4 ill try and get some #s up this week
Old Jul 18, 2005 | 01:27 PM
stuffy236's Avatar
have you scanned your car yet? are you getting any knock with the lower pulley?
Haily229
Sep 17, 2015 07:18 AM
Highgross89
20
Sep 11, 2015 03:24 PM
