Progress on my Dual Pass build, PICS!!
Old Aug 21, 2007 | 11:59 AM
Coblt ss super's Avatar
haha well everyone knows ive been so like into this build well, me and my uncle got to work the other day in installing my second surge tank for the option B kit, and here is the easiest way to make brackets for this, we decided to use wat the car already gave to use to use, and we made 2 simple brackets
theres the top view, we decided to use one of those threads on the top, and made a small bracket, and used the little opening on the surge tank, so we decided to weld a screw onto that bracket and put a nut on the other side of the surge tank, so itll be an simple take off when needed
and then the front bracket was a simple L bracket, that had 2 holes, one into the frame and then one that went into the hole already in the surge tank
The brackets are not gunan be staying like that, they will be painted the same color as the car, and the nuts and bolts i will be getting all new, and best part is, all this stuff, to make brackets, paint em, and nuts and bolts, cost me nothing!!!!
Old Aug 21, 2007 | 12:06 PM
BlackSS/SC's Avatar
Looking nice.
Old Aug 21, 2007 | 12:07 PM
now its time to do all the lines, and the dual pass it self, wat kinda coolant is everyone useing? and wat the hell is a cross connector? i have it and dont know wat its for
Old Aug 21, 2007 | 12:10 PM
-Jayson-'s Avatar
your supposed to use Dexacool, if you use anything else it will gunk up the coolant system
Old Aug 21, 2007 | 12:12 PM
ok thanks on that, and does anyone have any idea on that cross connector?
Old Aug 21, 2007 | 12:13 PM
Witt's Avatar
I like that setup for the surge tank, simple and clean.
You can use any type of coolant you wish as long as its all the same type in the system. I personally use 70% water, 30% dexcool and a bottle of water wetter I picked up from Summit.
Old Aug 21, 2007 | 12:16 PM
isnt there different types of dexcool also?
Old Aug 21, 2007 | 12:22 PM
Witt's Avatar
No, there should be Dexcool (different brands but its all compatible with each other) and then the standard green stuff.
I can't give you an answer on that cross connector as I did option A when I installed mine. Looking at instructions though, its shown in pictures when creating the air bleed line. Maybe its used as a donor for the .040" orifice, I'm not sure.
Old Aug 21, 2007 | 12:24 PM
lsjwannabe's Avatar
looks fimilar
Old Aug 21, 2007 | 12:34 PM
i still dont understand wat its used for
Old Aug 21, 2007 | 12:37 PM
lsjwannabe's Avatar
to bleed air i believe
Old Aug 21, 2007 | 12:39 PM
yeah but where does it go? wat hoses hook up to it?
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
goaliemo
Sep 28, 2015 01:37 PM
