pulley power
Old Dec 13, 2006 | 09:38 AM
cobaltstg2's Avatar
pulley power
does anyone know how much hp the 2.8 gives the car over the 3.0 .... just wondering cause i never had my car on a dyno with the 3.0
can the 2.8 pulley cause a cracked land ring or also know as a compression ring due to to much boost? this happen to me i just wondering
but i also did not let my car warm up on the previous day and it was like 20 degrees outside... so i get in my car and go wot through 1 and 2 gear and my girlfriend said all she saw was black smoke... never had a problem with the pulley till that day just wondering
so i am back to the 3.0 pulley with gmstg2 tune for the winter just wondering the numbers?????
Old Dec 13, 2006 | 12:03 PM
SSdan's Avatar
Hmm, extra 15 horsepower and 21 lbs of torque!!
Im gonna get one and a tune.
Old Dec 13, 2006 | 02:15 PM
ReMz's Avatar
for some reason i did not realize the gain was that substantial. i guess i didnt have my stock stage 2 on long enough to notice the change.
21lbs of torque is quite a bit!
Old Dec 13, 2006 | 02:23 PM
2K5SS/SC?'s Avatar
The real gain here is not just the 21ft lbs of torque, but how much earlier all that torque comes on. That's damn near a 1000rpms sooner. That's why I wasn't happy with my power numbers on the dyno, but the broadened torque curve and bump in torque made me smile.
Old Dec 13, 2006 | 02:37 PM
SSdan's Avatar
Wow, I didn't even notice that. The HP also comes on sooner as well.
Old Dec 13, 2006 | 04:27 PM
cybcow's Avatar
A general standard is for every .1" you get 5hp.
Old Dec 13, 2006 | 04:35 PM
glockglade's Avatar
assuming you keep the temps the same more boost = more heat.
Old Dec 13, 2006 | 04:41 PM
OniMirage's Avatar
but a 2.8 is too small right? it puts the duty cycle for the injectors over the limit and makes em go static no? or is there a tune someone is running that has solved that?
Old Dec 13, 2006 | 04:52 PM
glockglade's Avatar
alright i will settle this it depends on where you live if you are in high altitude it is probably ok but if you are closer to sea level i'd say no it all depends just to be safe stay under 6500rpm if u can. Like if your blowing the doors off a civic just shift a 5k so you don't have to worry about it.
Old Dec 13, 2006 | 04:58 PM
OniMirage's Avatar
i will just get a 2.88
Old Dec 13, 2006 | 05:33 PM
OniMirage's Avatar
its all about that high polish look oh so sexy
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
