pulley question
Old Apr 18, 2008 | 07:56 AM
along440's Avatar
pulley question
need help guys whats the safest size pulley to run with the gm stg 2 kit and the pulley size on the stg 2
Old Apr 18, 2008 | 07:57 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Without cooling mods we havent had anyone blow a motor on 2.9. I would suggest not going any lower than 2.8 if you really want to push it.
Old Apr 18, 2008 | 02:08 PM
06ssgm2's Avatar
when i had my stg 2 i was runnin a 2.85, it ran perfect.. had it like that for almost 6 months or so until 60's and smaller went on lol would push about 16-16.5 psi at top of third gear..
Old Apr 18, 2008 | 04:33 PM
along440's Avatar
thanks guys i want to keep my warranty i have had a few issues with the car a pulley swap is no biggie for me i plan on the dual pass later... i guess i'll be goin to a 2.9 side note my a/f is fat as hell around 10.5 or so just lookin to lean it up a bit
Old Apr 19, 2008 | 12:42 AM
jimmyfoxx's Avatar
it wont lean it up.. from what i have read countless times from people on this site, it will just work the injectors harder.
i would read up on it. i am just going to put together my own kit and get it tuned with a 2.9
Old Apr 19, 2008 | 12:53 AM
srowler9's Avatar
it only leans up the A/F ratio if the injectors go past their capacity. If you go over 100% efficiency, you will lean up the A/F ratio.
When you lean to much, the temp in the combustion chamber gets way to hot, causing melting of the internals or blowing the motor
Old Apr 19, 2008 | 12:54 AM
xx07cobaltss24xx's Avatar
it should lean it out
Old Apr 19, 2008 | 12:59 AM
srowler9's Avatar
A lot of people on here go 2.9 with a stage 2 flash, but when they are hooked up to hpt, some of them are running past the injector efficiency. I would not go smaller than a stage 2 pulley. I like to be more safe than sorry. If you do, make sure you get some cooling mods.
Old Apr 19, 2008 | 01:03 AM
Cobalt_SSTuner's Avatar
sell ur 42's get 60's and get a 2.8" pulley
Old Apr 19, 2008 | 01:07 AM
ColeJJones's Avatar
Bannned
^^ yep, run 2.9. i have a nates 2.9 pulley FS if interested
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
