Pulley question
Old Jan 13, 2006 | 04:43 AM
leeserlee's Avatar
Pulley question
so i just got my 06 coblat s/c and i see alot of u wanting a 2.8" pulley. So what does this pulley do and what are the pros/cons expected out of changing it. If anone could give me a gprice that would be great.
thanks
Old Jan 13, 2006 | 08:18 AM
Rusty's Avatar
smaller pulley = more boost
more boost = more hp
Old Jan 13, 2006 | 08:21 AM
R33P3R007's Avatar
360 L337 User
What he said. what is the average equation. +1lb = 8-10 hp.. ? is that right?
Old Jan 13, 2006 | 09:19 AM
mcz34man's Avatar
pulleys are nice i had a 3" pulley and a custom intake on my last ss/sc.....never took it to get dynoed but damn that car had some kick to it after i did that....i think i was running about 15 to 17 lbs of boost, i got my pulley for 55 off ebay, if you want ill give you the email for the guy that makes them
Old Jan 13, 2006 | 09:24 AM
Rusty's Avatar
if you could post contact info for this guy that'd be cool.
also, did you do ANYTHING else to the car besides pully and intake? no ecu mod (piggy back, flash)? any problems with the belt slipping?
Old Jan 13, 2006 | 09:32 AM
mcz34man's Avatar
here is the guys email, not sure if he still makes them but he prolly should, pulleytech@mcleodusa.net, didnt have any problems with belt slipping, getting the blet of is a little bit of a bitch but not to hard if you have some mechanical exp. only things i had done to the car were my exhaust, 3" pulley and the custom intake, that was plenty power for me until i can changes cams and pistons. i didnt do any smaller than the 3" cuz then you would need to flash the ecu and dealers dont really want to do that. so to save money go for the 3" get an intake and exhaust and you'll be throwin down some speed hope this helps
Old Jan 13, 2006 | 10:02 AM
BLKSS's Avatar
1psi = .1 sec on the track.
Old Jan 13, 2006 | 10:04 AM
BLKSS's Avatar
Not sure how long your SC will last with a 2.8. It will spin much faster resulting in more wear... And possible defects. But in general it should me ok. I mean its a kick ass upgrade for the money. If your planning on keeping the car for a long time go with the 3.0 from GM.
Old Jan 13, 2006 | 10:12 AM
memphisr24's Avatar
2.8 is the what i'm going with. It should make the car boost about 18lbs which should be about 25-30 more hp. Of course with a 2.8 you're going to need fuel upgrades such as injectors, new ecu or piggy back, spark plugs.
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
