Pulley Question
Old Jul 11, 2007 | 06:00 PM
drslash's Avatar
Pulley Question
I was wondering, what the smallest pulley size I can get for my cobalt ss/sc that I can run on stock injectors and stock ecu without damaging anything. Also, where can i purchase one from?
Old Jul 11, 2007 | 06:08 PM
XM15's Avatar
I wouldn't go with a smaller pulley without the bigger injectors or tune. The stage 2 pulley is 3" and the stock pulley is 3.3"; I don't think there is much room in between those sizes for the stock injectors. I think denny posted that the IDC on his stock injectors was too high to begin with.
I'm assuming from your post that you want to keep things fairly conservative for now. In that case, go with stage 2; you will keep your warranty and get a nice boost in power.
Old Jul 11, 2007 | 06:13 PM
justin04's Avatar
just get u a set of 60's amd a 2.9" pulley
Old Jul 11, 2007 | 06:19 PM
drslash's Avatar
Justin, what is an amd? I was thinking maybe a 3.05 or a 3.1 should be fine stock. Any suggestions?
Old Jul 11, 2007 | 08:04 PM
MadboostSS's Avatar
im running 42# injectors and a 2.8 pulley.. works fine no problems.. almost 2000 miles on it
Old Jul 11, 2007 | 10:57 PM
Onyxd04Redline's Avatar
I'm running a 3.2" and stock injectors
Old Jul 12, 2007 | 12:52 AM
RedEcotecSS's Avatar
dont need 60's for a 2.9...
Old Jul 12, 2007 | 10:23 AM
drslash's Avatar
Thanks. I think I am going to go down to a 3.1. I have the airbox mod, how much horsepower does anyone think i will be making then?
Old Jul 12, 2007 | 10:42 AM
R&C_rallySS's Avatar
IMO GM Stage II with one of Nate's custom made pullies is the best way to go. Go with Stage II, and a 2.95 pulley and you will be very safe. Get some other bolt ons to make air flow smoother and more free flowing and you will have a low 13 second car with traction
Old Jul 12, 2007 | 01:47 PM
chevysalesman614's Avatar
you should be good. 3.1 is ok on the stockers
noob ownage
Last edited by chevysalesman614; Jul 12, 2007 at 01:47 PM. Reason: Automerged Doublepost
Old Jul 12, 2007 | 01:51 PM
hawlyns711's Avatar
ooh this is a good thread for the question i have. on a stock tune, if you put a smaller pulley on wouldnt the bypass valve start bleeding after you hit 12psi?
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
