pulley size
Old Apr 25, 2007 | 06:01 PM
hispano1's Avatar
pulley size
hey i was just wondering what size of pulley i can actually use with 60 lb injectors, 2.5 custom exhaust and aem intake?? and then later on get a heat exchanger if needed...also i'll be getting a custom tune with hp tuners...i was thinking of 2.7 inch would be fine but i want to be safe then sorry...
Old Apr 25, 2007 | 06:04 PM
Boost Fr33k's Avatar
if your gonna use 60lb injectors might as well go with a 2.5" inch pulley, no sense of going with a 2.7 with the same mods accompanying a 2.5" you might wana get a bigger exhaust though.
Old Apr 25, 2007 | 06:15 PM
Area47's Avatar
Rent me! per hour
does the thought of overspinning the blower and turning it into a huge heater go out the window?
Old Apr 25, 2007 | 07:05 PM
hispano1's Avatar
what do you mean?? well i wana leave the exhaust 2.5 since i think that should be ok but aint sure...
Old Apr 25, 2007 | 10:02 PM
Shortbus's Avatar
With a 2.5 you will be overspining like a biotch, you will nuke your blower in time, also the amount of heat that creates will negate the torque you will gain, because going from a 2.7 to 2.5 is just going to be mostly torque, imo go with a 2.7, its right in the middle, and still produces good power, but also still produces much un-wanted heat.
Old Apr 25, 2007 | 10:44 PM
BLKblurr06's Avatar
best anwer so far, as for me I'm affraid to go below 2.8 because of all of the blown motors recently
Old Apr 26, 2007 | 10:26 AM
Saltbager's Avatar
I'd say best bet would be a 2.7 also. It's still creating a lot of heat though. Heat exchanged and meth injection are you friend though just remember that!
Old Apr 26, 2007 | 10:35 AM
CTCOBALTSSS's Avatar
Bro you could even do up a 2.8 with 60's and a nice tune. Less heat and power is still there and no overspin.
Old Apr 26, 2007 | 12:00 PM
Shortbus's Avatar
Yes that is actually a nice setup also, a 2.8 with 60s, add a h/e to that and your golden.
Old Apr 26, 2007 | 12:23 PM
lsjwannabe's Avatar
or you can jus do the dual pass end plate, run another h/e and port the blower like me than run a 2.5 you might wanna run meth to but iat2s are are not that bad without it
Old Apr 26, 2007 | 12:25 PM
Acidangel_5.0's Avatar
Old Apr 26, 2007 | 12:29 PM
Yep. The H/E would help big time. Exactly. That setup right there is nice for our cars.
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
