Pulley swap
Pulley swap
I have the gm stage 2 and i was planning on swapping the pulley. I have a book that shows the whole sc getting taken off and i was wondering if this is necessary. Can i put it on w/o taking the sc off?
thanks
thanks
It's actually quite simple if you've already got the stage 2 installed. Just loosen the bolts with the belt attached to keep the pulley from spinning, then remove the belt and let it rest on the supercharger snout to keep it from falling off the other pulleys. Next, remove the bolts and slide the pulley off, put the new pulley on and tighten the bolts. Finally put the belt back on and finish tightening the bolts (I suggest using the stainless steel cap screws I offer as they're much easier to work with!). The pulley and bolts are available at www.smoothflowpulleys.com/Stage2.html
Hope this helps,
Nate
Hope this helps,
Nate
patooyee
Oct 1, 2015 01:07 PM
