Pulley Swap with Blower on?
Old Mar 24, 2007 | 02:01 PM
brk_05's Avatar
Is it possible to do a pulley swap on the SS without removing the blower? I know you can on the Redline but there is a lot more room under the hood on the redline than there is in the ss/sc. I believe you can on the redline with the pulley boys puller.
Old Mar 24, 2007 | 02:07 PM
blueta's Avatar
There isn't a lot of room there but maybe you can with some finagling. Why not just pull it off? It's only 4 bolts and some sensors.
Old Mar 24, 2007 | 02:24 PM
QuikSilverSS's Avatar
If its the stock pulley, you will need a special removal tool, if you have a stage 2 or other aftermarket pulley on then you can just loosen the blet and unscrew the 4 screws holding it on.
I went to change mine last night, except when i put my 2.8" on the Mechanic tightened the screws so tight and added lock tight it wont come off.
Old Mar 24, 2007 | 03:26 PM
brk_05's Avatar
I know you need a pulley puller to do the job, but i was wondering if any of them worked while the blower was on the car. I just took another look under the hood and realized its not going to happen. I had a redline before the cobalt and you defintely could on a redline. Much more room under there on the redline. Oh well. I'll suck it up and take the blower off.
Oct 20, 2015 09:56 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
