Pulleys
there is no room with stock injectors to make more boost. if you look at the gm stage 2 kit, just by upgrading the injectors they make a bunch more power, meaning it was lean to start with.
there are several options. if your under warrenty and would like to keep it, then go with the gm stage 2 kit and have the dealer install it, that was the car will retain warrenty without issues. if you are not/dont want to retain warrenty, go with one of the vendors upgrade kits. id recommend a kit that have 60lb injectors (skip 42s cause in the future when you want to go a little faster it means bigger injectors) and a 2.9-3.0" pulley. once you have other supporting mods, such as a heat exchanger, dual pass, header, exhaust, etc. you can then drop pulley size again.
See this thread
https://www.cobaltss.net/forums/2-0l...-guide-217195/
patooyee
Oct 1, 2015 01:07 PM
