Pulleys
Old Aug 28, 2011 | 08:51 PM
RDBALT8's Avatar
Pulleys
What size of pulley should i invest in for my 07 ss? Want to improve on top end.
Old Aug 28, 2011 | 09:01 PM
metalmedic's Avatar
is ur car stock???
Old Aug 28, 2011 | 09:43 PM
rivaladore's Avatar
Yea what are your supporting mods. You can't just throw a pulley on. You are going to need injectors, cooling mods, a header and down pipe
Old Aug 28, 2011 | 09:54 PM
Sharkey's Avatar
there is no room with stock injectors to make more boost. if you look at the gm stage 2 kit, just by upgrading the injectors they make a bunch more power, meaning it was lean to start with.
there are several options. if your under warrenty and would like to keep it, then go with the gm stage 2 kit and have the dealer install it, that was the car will retain warrenty without issues. if you are not/dont want to retain warrenty, go with one of the vendors upgrade kits. id recommend a kit that have 60lb injectors (skip 42s cause in the future when you want to go a little faster it means bigger injectors) and a 2.9-3.0" pulley. once you have other supporting mods, such as a heat exchanger, dual pass, header, exhaust, etc. you can then drop pulley size again.
Old Aug 29, 2011 | 06:40 AM
insylem's Avatar
See this thread
https://www.cobaltss.net/forums/2-0l...-guide-217195/
Old Aug 29, 2011 | 07:30 PM
RDBALT8's Avatar
ok thanks guys! any other options i should do?
Old Aug 29, 2011 | 08:19 PM
Boosted05's Avatar
Actually read the sticky's and not just toss a thread up with no info in it at all....
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
