pully size
i just wanted to see if i can order a 3.0 pully or something other then stock size!! I do have the colder plugs and the tuner. i'm going to order pully this week so thats why i started this one. feed back u know!!
3.0 is safe with stock injectors. as long as u have a tune, my duty cycle is at 91%
Everything depends on how you drive your car. The two things to watch are intake temps and injector duty cycle.
Honestly running a 2.7" on the stage 2 tune would kick intake temps up at least 15 degrees but I haven't checked...I could check if someone wants me to...but I run richer than stage 2 tune when I run it (maybe 50 miles in 6 months?) so that might skew things.
Um...you have stage 2 correct?
Last edited by theneelster; Aug 12, 2008 at 09:53 PM. Reason: Automerged Doublepost
I have a custom tune with a 3.0 pulley stock injectors and my duty cycle is 91%
learning!
Last edited by simmonsnick; Aug 13, 2008 at 05:41 PM. Reason: Automerged Doublepost
2.9" with the stage 2 tune 2.6" is not safe short or long term. The smallest you should probably go for is 2.8" but that's pushing it.
2.9" is fine with stage 2 running the injectors that high is counterproductive but if you don't constantly go over 6k you should be fine. Intake temps around 155 driving hard in the summer.
im not gonna lie im no tuner at all I got it tuned with efi live by greenlightmotorsports.com all im saying is why would gm release a car with 120% idc and no i don't know the calculation for it im sure i can find out how, but efi live does it for u.
so whats this calculation for IDC?? ive only ever looked at EFI Live and it calculates it for you...
its not miscalculated efi live calculates it on its own. pw? spell it out im no tuner i don't know the lil phrases....
Last edited by cobalt ss/sc; Aug 13, 2008 at 08:33 PM. Reason: Automerged Doublepost
http://www.rceng.com/technical.aspx?...FHoz44mFzZsTzl
say you want 260 crank hp and a max of 80% idc's you need at least 42's.
Most people on stage2 make more hp then that at the crank hence why those idc's will always be over 80.
it can be
a guy i work with has efi live v2 scanner and it says it suports our cars but it won't read it for some reason do u know anything about that?
