pully size
Old Jul 14, 2008 | 10:15 PM
simmonsnick's Avatar
pully size
so if i get a bigger pully untill i can get 60 injectors what size would be safe with hp tuner onits way????
Old Jul 14, 2008 | 10:39 PM
restonSS's Avatar
well what are you now? completely stock? unless you have the stage 2 (42.5 lb) injectors, you shouldnt change anything regardless of hp tuners.
Old Jul 14, 2008 | 10:49 PM
2.6 zzp pully
Old Jul 14, 2008 | 10:51 PM
ColeJJones's Avatar
Bannned
you better get the stock sized pulley back on or buy a pulley that is that size to go back on that hub. and stop making threads asking the same questions
Old Jul 14, 2008 | 10:57 PM
i just wanted to see if i can order a 3.0 pully or something other then stock size!! I do have the colder plugs and the tuner. i'm going to order pully this week so thats why i started this one. feed back u know!!
Old Jul 14, 2008 | 11:03 PM
YellowRocketSS's Avatar
i got my stock one for sale..
Old Jul 14, 2008 | 11:06 PM
cobalt ss/sc's Avatar
3.0 is safe with stock injectors. as long as u have a tune, my duty cycle is at 91%
Old Jul 14, 2008 | 11:07 PM
restonSS's Avatar
what size injectors do you have?
Old Jul 15, 2008 | 12:00 AM
theneelster's Avatar
If you have a stage 2 tune or the zzp s2 tune then you're okay with anything 2.8-3.0. 2.6 has got to be sketchy without 60's.
Old Jul 15, 2008 | 12:16 AM
rrutter81's Avatar
stock injectors
stock pulley...your idc is like 120% @ 6500 rpm
42s
s2 tune 3.0 max
custom tune 2.9 max
custom tune 2.8 max if you limit 6500 rpm
the rest your playing with fire
Old Jul 15, 2008 | 12:27 AM
NexTnmE's Avatar
Originally Posted by rrutter81
stock injectors
42s
s2 tune 3.0 max
custom tune 2.9 max
Yup. When I got tuned...GM Stage II with 2.9" I had 116%IDC.
Old Aug 12, 2008 | 09:06 PM
ok i put a 3.1 on to be safe what should i do to tune?? yes i have hp tuners!!
Old Aug 12, 2008 | 09:21 PM
restonSS's Avatar
do you even know how to tune?
Old Aug 12, 2008 | 09:53 PM
2.9" with the stage 2 tune 2.6" is not safe short or long term. The smallest you should probably go for is 2.8" but that's pushing it.
stock injectors
42s
s2 tune 3.0 max
custom tune 2.9 max
2.9" is fine with stage 2 running the injectors that high is counterproductive but if you don't constantly go over 6k you should be fine. Intake temps around 155 driving hard in the summer.
Everything depends on how you drive your car. The two things to watch are intake temps and injector duty cycle.
Honestly running a 2.7" on the stage 2 tune would kick intake temps up at least 15 degrees but I haven't checked...I could check if someone wants me to...but I run richer than stage 2 tune when I run it (maybe 50 miles in 6 months?) so that might skew things.
Um...you have stage 2 correct?
Last edited by theneelster; Aug 12, 2008 at 09:53 PM. Reason: Automerged Doublepost
Old Aug 13, 2008 | 12:00 PM
stock injectors
42s
s2 tune 3.0 max
custom tune 2.9 max
why the hell would gm run a car with the duty cycle at 120% from the factory? they wouldn't do that!
I have a custom tune with a 3.0 pulley stock injectors and my duty cycle is 91%
Old Aug 13, 2008 | 12:05 PM
lsjwannabe's Avatar
idc's can be miscalculated what is your pw. I bet it is over 17ms
Old Aug 13, 2008 | 05:41 PM
what did u do to the tune ??
learning!
Last edited by simmonsnick; Aug 13, 2008 at 05:41 PM. Reason: Automerged Doublepost
Old Aug 13, 2008 | 05:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
i have a feeling he has no idea.
no!!
Old Aug 13, 2008 | 08:33 PM
im not gonna lie im no tuner at all I got it tuned with efi live by greenlightmotorsports.com all im saying is why would gm release a car with 120% idc and no i don't know the calculation for it im sure i can find out how, but efi live does it for u.
so whats this calculation for IDC?? ive only ever looked at EFI Live and it calculates it for you...
its not miscalculated efi live calculates it on its own. pw? spell it out im no tuner i don't know the lil phrases....
Last edited by cobalt ss/sc; Aug 13, 2008 at 08:33 PM. Reason: Automerged Doublepost
Old Aug 13, 2008 | 10:11 PM
pw=pulse width.
Old Aug 14, 2008 | 12:30 AM
lsjwannabe's Avatar
it can be
http://www.rceng.com/technical.aspx?...FHoz44mFzZsTzl
say you want 260 crank hp and a max of 80% idc's you need at least 42's.
Most people on stage2 make more hp then that at the crank hence why those idc's will always be over 80.
Old Aug 14, 2008 | 01:25 AM
it can be
hey thanks for settin me straight... i guess i should do the calculation and not just read what efi live says.... and im gonna see what my pulse width is
Old Aug 14, 2008 | 01:27 AM
lsjwannabe's Avatar
http://www.stealth316.com/2-calc-idc.htm
another useful site
Old Aug 14, 2008 | 01:31 AM
hey thanks man
a guy i work with has efi live v2 scanner and it says it suports our cars but it won't read it for some reason do u know anything about that?
