pully sizes
Old Mar 24, 2009 | 09:01 PM
BLKLS's Avatar
pully sizes
so whats the gm stage 2 pully size, i have just this past weekend looking into supercharging my 2.2. i have looked around for a bit but still haven't found it.
also, if i get a sc from on the board here and it has a stock pully on it still, can i just change the pully or does the hub need to be changed also? cause i see that zzp sells a moduler pully set up mut if i don't need to change to much, then it would be that much easier.
i'm thinking of doing the stage 2 pully, #42 injectors, an intake, dual pass, zzp aftercooler and option b as far as aftermarket parts on the intake side of thing, i already have a full exhaust so not worried there, and a tune from trifecta. any sugestions from you guys would be great, seeing as i only have about 6 hours total looking up lsj stuff.
Old Mar 24, 2009 | 09:02 PM
SlyderRE's Avatar
stage 2 is 3", or 3.05......... whatever ppl prefer
Old Mar 24, 2009 | 09:08 PM
~Mike~'s Avatar
could be wrong here, but I'm pretty sure the stg 2 pulley is 3.1 and stage 3 is the 3.0. I just had this discussion earlier with another member on here lol
Old Mar 24, 2009 | 09:12 PM
TurboTommy's Avatar
2.9 with a stage II tune is the lowest i would go
Old Mar 24, 2009 | 09:19 PM
~Mike~'s Avatar
If you wanna drop pulley sizes from the stock 3.35 that's on there, then yes you have to get the hub too. If you get the MPS from ZZP it'll have everything you need to do it besides a pulley puller. if ur gonna run 42#ers you can't really go any lower than a 2.9 as stated above. and get a custom tune, gm tunes suck lol
Old Mar 24, 2009 | 09:22 PM
chris88z24's Avatar
No..
Old Mar 24, 2009 | 09:28 PM
Hockeyman's Avatar
s2 = 3.06
gm s3 = 2.99
Old Mar 24, 2009 | 10:20 PM
BLKLS's Avatar
if the 3.35 is stock, stg 2 is "3", then whats the point of the 3.1
so i need a hub to change the pully to any size, is that what your saying?
i'm more intrested in getting it together and running then making a lot power, from what i read a stg 2 pully is on the edge of the stock rods in a 2.2 can handle, and being as the very soon to be wife dosen't know i'm thinking of spending this money then a bottem end isn't in the near future
thanks
Old Mar 24, 2009 | 10:24 PM
chris88z24's Avatar
stage 2 is technically 3.1, stage 3 is 3"
mmk?
Old Mar 24, 2009 | 11:06 PM
~Mike~'s Avatar
Yes, if you want to change the pulley from stock you need to get the hub too. IF you're actually gonna do this, get the M62 and the MPS from ZZP or another vendor on here. Or just stick with stock. Stock the blower puts out between 10-12.5 psi and if you go stage 2 that'd be around 15psi give or take.
https://www.zzperformance.com/cobalt...=446&catid=142
OR
http://smoothflowpulleys.com/Stage2.html <--The MPS system
That's what you need to buy to swap pulleys.
Old Mar 25, 2009 | 07:45 AM
BLKLS's Avatar
Thanks
Old Mar 25, 2009 | 08:32 AM
thecobaltguy's Avatar
most stage kits will give u everything u need plus the hub...im not sure what the 2.2 can handle but with my 2.0 i dropped to 2.6 and 60's
Old Mar 25, 2009 | 09:30 AM
BLKLS's Avatar
That sounds like way to much. They say 250 crank and the rods are done.
I'm not trying to make the fastest car on the block i just want it to be fun, i figure this is gonna be the best way to make good power and not brake the bank
Old Mar 25, 2009 | 09:41 AM
lsjwannabe's Avatar
Stage two is 3.06" Stage three is 2.99"
Blkls you have a pm
Old Mar 25, 2009 | 09:44 AM
cgrammer's Avatar
Sub'd because I have no idea what to get for the Stage 2 kit, either.
Old Mar 25, 2009 | 09:53 AM
rnjmur's Avatar
Stage 2 pulley size is 79mm or 3.11 inches. Stage 3 is 76mm or 2.99 inches.
If you get a SC with a stock pulley you will need to get the pulley off then put a hub on. Stage 2 pulley with 42 pound injectors should be fine. I don't know how much more you can push out of the 2.2 without upgrading the internals though.
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
