Pulsing 3rd gear at 90+ mph
my surge was around 95-100mph...and it would feel like if i let go of the gas on purpose and slame the gas again...was starting to **** me off
i know he is running California 91 **** water.. maybe the 2 step colder is alittle to cold? i mean **** i see so many people doing the stage 2 with 2.9 on the factory plug's.. and the colder step plug's is to help knock right? he need's to log it when it happen's so we can really see what's going on..
and BTW steven i saw you at the downey yesturday. i was with my grandma.. and i noticed somthing while leaving.. you got a sick ass hood on your car.
start from scratch. i have an 06 or 07 stage 2 map. remove all adders in terms of timing. afr adder. ect adder below 210 degree's. iat adder below 140.
leave the fuel, and the timing stock stage 2. then try it again.
something is goofy and it's most likely something simple you're overlooking
Will do sir, Hopefully its tune related and not mecahnical. Thanks for the help.
So thats about as far as that convo goes.Not entirely true. my car used to get spark blow out only in 3rd gear when i tried to lean out the tune. But in second gear the car pulled just fine. If it was mechanical, or even if it was based off the "tune" it doesnt ALWAYS have to happen in every gear.
Last edited by shaunmcdee; Feb 11, 2008 at 03:26 PM. Reason: Automerged Doublepost
kk... to clear things up a bit...
Every gear runs like a champ, except the top of 3rd. Once I hit 90mph in 3rd gear, roughly 6k on the tach, it begins to pulse until I shift it into 4th.
thanx man!
Last edited by Steven Flit; Feb 12, 2008 at 02:42 AM. Reason: Automerged Doublepost
Problem solved folks
Cleaned the MAF and replaced the stock filter. It had 17,000 miles on it.
Shaun and I first put in the stock spark plugs. And were still getting the pulsing at 90+ mph in third.
Once we replaced the filter and carb cleaner on the maf, the problem was solved.
Tonight we're going out to do a final tune on the car; decided to just keep the stock sparks on.
thanks for all your help guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
