purchases in order..
Old Sep 14, 2009 | 05:06 PM
Mclovin23's Avatar
Ive basically decided on the OTTP kit but when ordering it it asked what aftermarket stuff do have on the vehicle. the only thing on it right now is intake but i would like to add full exhaust as well.
if i get the stage kit before i get the exhaust will that throw the tune off on it or is exhaust not as serious of an issue?
Old Sep 14, 2009 | 05:18 PM
Josh@ottp's Avatar
It won't throw the tune off. Other things like an intake or tvs would though.
Old Sep 14, 2009 | 06:36 PM
Jn2's Avatar
Jn2
no you will be fine, a exhaust wont really make a new tune neccessary....get the staged kit... you will be fine upgrading to a bigger exhaust later down the road
Old Sep 14, 2009 | 07:32 PM
Mclovin23's Avatar
sounds good and thanks for the help.
i think i'll go intake, OTTP stage 1( with h/e, dual pass, and option b) then exhaust.
as for those cooling mods. are all necessary for that setup im looking at or is one more necessary than the other?
Old Sep 14, 2009 | 07:33 PM
Jn2's Avatar
Jn2
what pulley size r u running, would def recommend dual pass no matter what, dual pass and a second h/e should be fine for anything as small as a 2.8...opt b is pretty useless unless ur using a flow thru set up
Old Sep 14, 2009 | 07:44 PM
Snakes709's Avatar
header, 3" downpipe and 3" exhaust messed my AFR up pretty bad..lol, but with just a normal exhaust....no should be fine
Old Sep 14, 2009 | 07:54 PM
Mclovin23's Avatar
Well i would prolly go 2.5"downpipe and exhaust. i dont think ill be pushing enough HP to worry about 3" at that time. i was thinking about a header to. how constrictive is the stock header? which one do you prefer?
Old Sep 15, 2009 | 12:17 AM
Snakes709's Avatar
The stock header is very constrictive...i bought the 4 into 1 header from CIA, really good price and good quality...When i had my header, 3" downpipe and 3" exhaust i was making 281whp with the tvs, pushing 20psi of boost so kinda needed it. Didnt play around with the tune much so thats why i made low numbers...heres a pic of the stock header vs the cia header
Old Sep 15, 2009 | 02:07 PM
Mclovin23's Avatar
holy hell that does look restrictive. what header and downpipe did you go with? howd it fit together?
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
allpro666
Sep 24, 2015 04:42 PM
ROADKONE
Sep 9, 2015 02:32 PM
