The quest for 600whp
Old 12-11-2013, 03:23 PM
  #251
armcclure's Avatar
Yeah. Not cool. Extended keyways for erryone.
Old 12-11-2013, 04:23 PM
  #252
Got Bewst?
Bluelightning's Avatar
I know a few of you have sheared that key, but it's not even something zzp pushes or really see on their builds. Scythe Snake, Cmiller ect I don't believe have ever had an issue like that. Not that I know of anyways.
Old 12-11-2013, 04:32 PM
  #253
TStone's Avatar
You're right, they don't have the extended keyway..
But, is it worth the risk?
Old 12-11-2013, 04:36 PM
  #254
InfraRedline's Avatar
If the motor is together and solid, I'd say leave it, but thats just me. If it shears off you will wish you took it apart and extended it, and if you take it apart and re-assemble and have an issue you will wish that you left it alone. Damned if you do and damned if you don't.
Old 12-11-2013, 04:38 PM
  #255
TStone's Avatar
hmm.. why would you have an issue reassembling?
Old 12-11-2013, 04:42 PM
  #256
Why could anything happen? Sometimes things happen. It could blow up next time he starts it or it could run for 10 years at 600whp, who knows. And then you'd wanna re-ring it and quick hone it again too if you took it apart. Its his call. I just know what I'd do, but its not my build.
Old 12-11-2013, 04:47 PM
  #257
Got Bewst?
Don't get me wrong it's a great idea if you are building a motor. Is it worth tearing a motor down just to do it? No I don't think it is IMO unless you actually have a key shearing issue. Replacing all tty bolts and gaskets to do. It's just not a common failure. Seems to be more prone with guys who have blowers. That I've seen anyways.
Old 12-11-2013, 04:50 PM
  #258
TStone's Avatar
Ohhhhhhhh you meant something else happens shortly after doing the crank and you gotta rip it apart anyways. okay gotcha.
  #259
Agreed. I'm not saying dont do it when building. Just the fact that its together and seems to be solid. "Let it ride!" comes to mind lol
Old 12-11-2013, 05:01 PM
  #260
Originally Posted by 574
Speaking of the oil pump, I just realized in the past few days I'm gonna have to take my crank out have have the keyway extended because of the ATI
What keyway is this you speak of? For an oil passageway or something?
I just bought my ati and zzp machined front cover thats all i got to run it so far and i gotta keep adding stuff to my list to keep on top of things lol
Old 12-11-2013, 05:04 PM
  #261
574
574's Avatar
If the key strips then you have no oil pressure, just put it that way. Your not built so if it strips in a year or two and you don't boom by then you can just build and it wouldn't be too big of a deal.
When I rebuild "hopefully in a few years" and the crank is out, yes I will have the key extended. But for now I think I've decided to take the gamble and just let er eat
Old 12-11-2013, 05:05 PM
  #262
South Central *********
JapEatr's Avatar
ATI damper seems to reduce the need for the extended keyway due to the interference fit, and also the hardened oil pump gears due to less crank pulley expansion on the oil pump
gears
Old 12-11-2013, 05:18 PM
  #263
Got Bewst?
gears
Agreed. Definitely helps things.
Even if you did twist the key off the pressed fit of the ati would probably still be enough to keep the pump turning. Limping that is.
Old 12-11-2013, 05:21 PM
  #264
574
574's Avatar
I thought the only time people extended them was when running an ATI?
Old 12-11-2013, 05:23 PM
  #265
Got Bewst?
No. Stock damper or ATI it sits the same amount on the key way. Just the stock sliders right on where the ati is a pressed fit.
Old 12-11-2013, 05:28 PM
  #266
574
574's Avatar
And thats why I need a heat gun? Why did no one tell me about this when I was building it for 6 months?!
Old 12-11-2013, 05:34 PM
  #267
TStone's Avatar
Heat gun for what..........?
Old 12-11-2013, 05:35 PM
  #268
SPDDMN36's Avatar
I plan on turning some rpms and the wheels are already in motion for buying internals so I'll be extending the keyway
Old 12-11-2013, 05:40 PM
  #269
574
574's Avatar
I was told to heat the area where it slides on
Old 12-11-2013, 05:42 PM
  #270
TStone's Avatar
EW. don't know if i like that idea.
Longer bolt, press it on just like anything else... Just be extra, extra extra sure its lined up wit the oil pump..
or to be the most sure it's lined up, take the timing cover off, put the ATI in the timing cover, press the ATI on with the timing cover already on it.
Old 12-11-2013, 05:46 PM
  #271
Got Bewst?
ATI suggests one way to put it on his use a heat gun on the centre where the crank slides on and slip it on. Done it twice now. Works like a charm.
Old 12-11-2013, 05:49 PM
  #272
574
574's Avatar
Timing cover will be coming off to put in ARP timing bolts so I'll probably do that
Old 12-11-2013, 05:52 PM
  #273
Got Bewst?
My way is easier
Old 12-11-2013, 05:53 PM
  #274
574
574's Avatar
I don't even have it in my hands yet, so it's hard to picture what everyone is saying
Old 12-11-2013, 09:15 PM
  #275
BlkWdoSS's Avatar
yea be careful that everything is in line when you start to press it on, If it isnt lined up, you will destroy the oil pump gears and the key. I have seen it done. check twice, install once
Even with it being pressed on I would worry about it slipping if the keyway breaks, the amount of resistance that you will be seeing on the pulleys at a high rpm may be enough to cause it to spin much slower than the engine
Quick Reply: The quest for 600whp
