The quest for 600whp
Old 12-06-2013, 06:30 PM
  #176
nhanson's Avatar
These trans are plentiful in my area
Old 12-06-2013, 06:39 PM
  #177
South Central *********
JapEatr's Avatar
Grab me one nick!
Old 12-06-2013, 06:51 PM
  #178
ItalianJoe1's Avatar
All this 4.45 talk and I keep thinking of looking for an LNF trans so I can hit 140 in 3rd gear
  #179
574
574's Avatar
Originally Posted by JapEatr
Grab me one nick!
I pictured you as an f40 man lol
Old 12-06-2013, 06:53 PM
  #180
JapEatr's Avatar
Less gears = more go fast... I dont need a double overdrive
Old 12-06-2013, 07:02 PM
  #181
574
574's Avatar
I like that idea too. But that means less traction
Old 12-06-2013, 07:44 PM
  #182
armcclure's Avatar
Smh if you're not getting traction get better tires and setup.
Old 12-06-2013, 07:46 PM
  #183
574
574's Avatar
Thats what I said too!! I just got off the phone with a good friend and had a long discussion about this and said you get sticky tires you'll just break other ****. Meh with the 4.45 hopefully I'll just have to worry about axles and clutch
Old 12-06-2013, 11:21 PM
  #184
armcclure's Avatar
And that is exactly why i run stock axles. I like to think of them as a shear pin.
Also.. As long as you avoid wheel hop at all costs, things will take a lot more abuse than your think.
Old 12-06-2013, 11:26 PM
  #185
574
574's Avatar
You think Napa axles would still be a safety feature? I think I need new ones so I was gonna get those
Old 12-06-2013, 11:39 PM
  #186
armcclure's Avatar
Yeah but honestly I'd just go with oem. Napa ones don't seem to last as long IMO and have been proven to not hold up to high speeds as well.
Old 12-07-2013, 01:56 AM
  #187
slitterell's Avatar
I have the ottp axles, same as napa from what I have heard, and they having let me down with slicks and 3-4k launches
Old 12-07-2013, 01:57 AM
  #188
slitterell's Avatar
small sample size but just noting
Old 12-07-2013, 02:18 AM
  #189
I personally saw a stock LSJ axle twist off from just power in the ~450whp range. Full traction in the middle of 3rd gear, about 80mph, clean break inside the outer CV boot.
Old 12-07-2013, 08:58 AM
  #190
mrbelvedere's Avatar
one of the things that kills axels is from lowering the car to far it binds up the axels
Old 12-07-2013, 09:01 AM
  #191
armcclure's Avatar
Weird. Makes me wonder if it had been weakened prior.
Old 12-07-2013, 09:16 AM
  #192
grrrrr weak baby weak
Old 12-07-2013, 11:05 AM
  #193
BlkWdoSS's Avatar
I twisted a stock axle off with stg 2 and stock ride height and no wheel hop on the run. If you are going to build a badass drivetrain, be sure that the cheapest part is the weakest link.
When you launch something has to break its potential energy and become kinetic energy for motion to occur. If the static friction of the tires isnt overcome then something will break or slip or shear off.
Old 12-07-2013, 03:52 PM
  #194
574
574's Avatar
Well I guess it's a crapshoot and the only thing I can do is keep stock axles on hand and let 'er eat
Old 12-07-2013, 08:05 PM
  #195
BlkWdoSS's Avatar
Thats what I do, I dont go the track without a spare set just in case and its not like its hard to swap them out.
Old 12-07-2013, 09:14 PM
  #196
slitterell's Avatar
You remember helping me swap mine out, right? Lol
Old 12-07-2013, 09:27 PM
  #197
BlkWdoSS's Avatar
yours was a special case Sean, someone welded yours to your diff inside the transmission lol
Old 12-07-2013, 11:30 PM
  #198
slitterell's Avatar
rust....might as well be welded lol slide hammer took care of it though. cleaned it up and put some sealant on it to keep it from doing it again.
Old 12-08-2013, 10:57 AM
  #199
BlkWdoSS's Avatar
I know lol, I was exaggerating, but was a complete pain to get that out
Old 12-08-2013, 09:04 PM
  #200
574
574's Avatar
How important are hardened oil pump gears?
Quick Reply: The quest for 600whp
