The quest for 600whp
Thats what I said too!! I just got off the phone with a good friend and had a long discussion about this and said you get sticky tires you'll just break other ****. Meh with the 4.45 hopefully I'll just have to worry about axles and clutch
Also.. As long as you avoid wheel hop at all costs, things will take a lot more abuse than your think.
I personally saw a stock LSJ axle twist off from just power in the ~450whp range. Full traction in the middle of 3rd gear, about 80mph, clean break inside the outer CV boot.
I twisted a stock axle off with stg 2 and stock ride height and no wheel hop on the run. If you are going to build a badass drivetrain, be sure that the cheapest part is the weakest link.
When you launch something has to break its potential energy and become kinetic energy for motion to occur. If the static friction of the tires isnt overcome then something will break or slip or shear off.
