The quest for 600whp
Old Jan 14, 2014 | 09:18 AM
  #426
jhaddock21's Avatar
Originally Posted by taintedred07
Damn are you still on stock lsj block???
Yep. Stock motor valve cover to oil pan.
Old Jan 14, 2014 | 09:20 AM
  #427
jhaddock21's Avatar
Originally Posted by 574
Some good tire info in here, and sorry Rice, no hub swap for me. If I can hook from a 40 roll I'll be a happy camper
Also is there any benefit to having the FPR in the engine bay rather than under the car?
Having it in the bay just makes for easy adjustment. I have it right on the end of the rail. Plus it looks pretty
Old Jan 14, 2014 | 09:54 AM
  #428
InfraRedline's Avatar
Jon ain't no bitch!
Old Jan 14, 2014 | 10:28 AM
  #429
armcclure's Avatar
Lol it's funny because at first, I was the hesitant one. Then once we were on the rollers I was eggin him on!
Old Jan 14, 2014 | 11:05 AM
  #430
I can see you when his car was on the dyno...
Old Jan 14, 2014 | 11:59 AM
  #431
armcclure's Avatar
Lol that's about how it went once we hit the 490's.
500 was gonna happen one way or another!
Old Jan 14, 2014 | 12:21 PM
  #432
jhaddock21's Avatar
Jon ain't no bitch!
Haha damn right! I was happy when it put down around 480 then Alan was like "give it another turn" haha I wanted the stock motor record!
Old Jan 14, 2014 | 12:26 PM
  #433
"In LSJ We Trust"
Old Jan 14, 2014 | 12:36 PM
  #434
Originally Posted by mrbelvedere
not always
ive seen slicks get blown off on a 11sec street car
you really speak in absolutes huh lol
Old Jan 14, 2014 | 01:08 PM
  #435
armcclure's Avatar
Only if it projects his intended opinion. And I don't mean that in a bad way. It's one of the keys to achieving persuasion in a debate.
He's very good at that. I think he missed his calling to be a lawyer
Old Jan 14, 2014 | 01:10 PM
  #436
armcclure's Avatar
Lmao and Juan was just running around hooting and hollering like a 3 yr old at chuck-e-cheese
Old Jan 14, 2014 | 01:13 PM
  #437
bmxracerchamp12's Avatar
I'm still confused how just return systems work vs boost reference. Bottom line is I got this baby in the mail today and I have to figure out what I wanna do with it
i bought the boost reference. tim was suppose to email the instructions for install but i havent got them yet. but my question is this. you guys have the factory return. i only have 1 line up to my rail. so should i switch to the lsj rail or keep my stock and run the boost reference from the back?
Old Jan 14, 2014 | 01:35 PM
  #438
mrbelvedere's Avatar
no just from experience
its not really an opinion tires only work as well as the chassis allows them to
Old Jan 14, 2014 | 01:55 PM
  #439
armcclure's Avatar
We only have one line running to our rail also.
Old Jan 14, 2014 | 01:59 PM
  #440
So what do you suggest for getting a 600hp street car to hook as good as it can Jon?
Old Jan 14, 2014 | 02:21 PM
  #441
My setup will be: Pedders coilovers on le stiff, ZZP control arms, and my 17x9" wheels with probably some 235/40 NT05's, but I am leaning more and more towards running a radial all the time up front. Haven't ordered tires yet. Anything to add, feel free.
Old Jan 14, 2014 | 02:25 PM
  #442
armcclure's Avatar
Alloy arms (lucky cobalts)
leading and trailing cabs
footballs if you're cheap, bags if you're not
strap the front
Then add the tire of your choice.
Old Jan 14, 2014 | 03:05 PM
  #443
I'm just talking street. Of course I have footballs for the track, and slicks. And of course for those big callouts on the street
Old Jan 14, 2014 | 03:10 PM
  #444
im only alloy control arms and rear bushings. i never thought i would get off the s/c and stock clutch. i never rarely launched it so i never invested in the fronts. its on my list now along with powell trans mounts. i have poly trans mounts now and the car shakes pretty good with the stage 2 cams
Old Jan 14, 2014 | 03:33 PM
  #445
car shakes pretty good on stock everything lol
Old Jan 14, 2014 | 03:50 PM
  #446
then you havent seen my car... stage 2 cams on a 750rpm idle. my parents are like,"why does your car shake when it idles and it sounds like it has a miss?"
Old Jan 14, 2014 | 04:57 PM
  #447
I havent seen ur car because noone posts stg2 cam videos!!
Old Jan 14, 2014 | 05:08 PM
  #448
Im running mine from the back.
Old Jan 14, 2014 | 05:09 PM
  #449
Old Jan 14, 2014 | 05:15 PM
  #450
you need to run spherical cabs get rid of arm windup
you don't want to tie the front end down it dose need to be able to move so you can control the car you want to control the weight transfer and chassis movement from the rear the rear it also needs to be free but limited in moving also
get the car on a drive on rack and look at the a-arms you want to set them slightly in an upwards direction
raise the back up a little and add bags you can also do a custom rate rear spring along with bags
the idea is when you launch the car the arms come as close to or just past level and stay there(the whole time your on the gas)now you have the pressure of the bags forcing the weight back forward trying to shove the front back down putting weight on the front tires and you have the car trying to shove the ass down adding weight to the front also
if you don't want to go off of the a-arms you can use the body set it up to where the car sets down in the front and goes to level on launch or just a bit nose down still
you don't want the car to just slam the on bags you want to control how fast it transitions by slamming on the bags you can unload the front creating wheel spin
