Question
Old Apr 2, 2006 | 06:29 PM
cashstacker's Avatar
Question
Has anyone thought about disconecting the hose that runs to the intake and putting a breather on it? Would you se better results from keeping it hooked to the intake or if it had it's own filter?
Old Apr 2, 2006 | 07:00 PM
sheek360's Avatar
I think if its unhooked, with a breather filter, you will see better. Some of the RL guys have it done. But I believe you would have to plug both ends with a breather filter element.
Old Apr 2, 2006 | 08:31 PM
i dont thin your would want to put a filter on the intake when you disconnect the hose it would allow air to escape. I was thinking of plugging that hole.
Old Apr 2, 2006 | 08:44 PM
CTCOBALTSSS's Avatar
It's not worth the power gains and I use the word power sparingly, you know what I mean.
Old Apr 2, 2006 | 09:12 PM
sheek360's Avatar
You can plug the intake. I dont see why not. Just make sure you clamp a filter on the other end of the hose.
Old Apr 2, 2006 | 09:38 PM
Why not worth the gains?
Old Apr 2, 2006 | 09:51 PM
AlphaJaguar5's Avatar
Its not about power its about taking care of your car so the oil blown through the head doesnt go into your supercharger and intake, combustion areas. It's called preventative maintainence not power
Old Apr 2, 2006 | 09:57 PM
silverSS's Avatar
Just curious, why was it designed like this on every single car(for the most part), if it severly hurts the engine?
Old Apr 2, 2006 | 10:13 PM
So we have to buy new ones sooner.
Old Apr 3, 2006 | 06:51 PM
sheek360's Avatar
If your gonna run a pulley, intense, rev it up, gm or any other power adders you run the risk of making a big mess!
If you arent flooring it, then you are less likely.
Old Apr 3, 2006 | 07:21 PM
bredick's Avatar
1 word... Emmissions.
Old Apr 3, 2006 | 07:23 PM
Brian MP5T's Avatar
Do you really think it will make a noticable diference?
I bet it's all in your head.
Old Apr 20, 2006 | 11:34 AM
Smokem10's Avatar
I have heard that in our engines, gas is also escapes through the valve cover hole and if you put a filter on it, then the gas doesn't get sucked out and you will have a really big accident (engine blows up). I want to do the same thing, but when I was told that, I left it alone. I want WOPONTOUR to respond, he is very knowlegable on these cars.....
Old May 25, 2006 | 02:27 PM
fWdCoBaLt's Avatar
So has anyone gone ahead and put this through? i want to do it because it just seems to make sense.
Old May 25, 2006 | 02:35 PM
snobird's Avatar
pretty much like said before prevents oil from getting into your cai etc also it is mostly for looks and will not add hp nothing bad will happend just a simple mod for looks
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
