question about heads
Old Apr 13, 2009 | 04:46 PM
07blackg5's Avatar
Slobodan Milošević
is the 2.0/sc head any different than the 2.2 head?
i was thinking about getting head work done on my 2.2, and thought about the 2.0 head. its the same block between the 2 engines, so the heads should be interchangeable. my question is that if the 2.0/sc head is more free flowing. i looked on gmpd and they show 3 different heads but they are all listed for all 3 engines.
i want to get some cams, and possibly head work done, but i the ss/sc head is better it would probably be cheaper to just pick one up from a junker (rather than getting my head ported).
that was worded horribly, but i think you will understand.
Old Apr 13, 2009 | 04:48 PM
REIGN SS's Avatar
Original Hayden Fanatic
Moved to 2.0 LSJ
Old Apr 13, 2009 | 04:53 PM
07blackg5's Avatar
Slobodan Milošević
sorry, i just figured it was a question 2.2's would ask, but it was a question about a 2.0 part. its also something anyone can answer, so i put it in general.
Old Apr 13, 2009 | 04:56 PM
ShortStack's Avatar
you are going to have trouble finding cams for the 2.0 lsj.
Old Apr 13, 2009 | 05:03 PM
07blackg5's Avatar
Slobodan Milošević
from what i understand people have run the the stage 2 comp cams in their lsj...
i may be wrong but im pretty sure ive seen it done
http://www.youtube.com/watch?v=YdKcA1LjM4E
Old Apr 13, 2009 | 06:45 PM
StevesBlack06's Avatar
their are lots of cams for the lsj, JBP makes 2 sets, im know GMPP and comp make grinds as well as HKS regrinds. im sure anyone would grind you anything you want to be honest. depends on how deep your pockets are. as for the blocks being the same... yes and no. the 2.0lsj has more accessories involved like an oil cooler and other crap. head should work but im not sure about clearances when it comes to the valves and whatever else. the cranks are the only thing that changes the displacement on these engines so thousands of an inch differance could be problematic. its not as simple as one would be led to think
Old Apr 13, 2009 | 06:55 PM
ShortStack's Avatar
^^^ If you can find GMR cams... more power to ya...
Old Apr 13, 2009 | 07:29 PM
Stiner's Avatar
Just port your current head...less headaches that way
Old Apr 13, 2009 | 07:59 PM
HunterKiller89's Avatar
the LSJ head and the L61 head flow almost the exact same numbers, but the head passageways are actually different. Basically, a port on one of them could cut right through a coolant passage on the other. But again, they flow almost the exact same, and they have the same valvetrain excluding valves. Theres a bigger aftermarket for the 2.2 head though, so I would just port the 2.2 one out if you want to increase flow.
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Sep 28, 2015 12:51 PM
