question bout intense stage 3
Originally Posted by ReMz
i believe i heard something about waiting for the GM Stage 1/2 reflash before purchasing an Intense Stage 3... is this correct?
i got the intense kit on my car and no problems with it at all.clutch is holding up just fine.second gear it pulls real hard. know that i got the kit nobody trys to race me that sucks.but im going to baytown this weekend so ill have some track times.the kit is very worth it and for those waiting for gm dont hold your breath.
Originally Posted by theBLUEone
No, you do not need any kind of Stage 1 or 2 from anywhere including GM to install the INTENSE kit...
Originally Posted by Jmc007
Because with tha kind of power, the clutch will be destroyed. Stock clutch sucks.
I thought it was maybe the car would start bucking or misfiring or running weird...if it does none of those then its fine to hell leave it in 4th at idle and punch it to redline.
Dan
Originally Posted by djt81185
Bull...The car is barely making 200ftlb below that. High load low rpm will not destroy a clutch...slipping and applying too much torque will.
Dan
Dan
My clutch already slip on high load at low RPM's in second gear, not because I made it slip, just because of the engine torque. I was only modded with a 3" pulley when it happened. Again, stock clutch sucks ...
Originally Posted by memphisr24
I have a question.
For the 3 inch idler pulley, in order to put it on, do you have to grind anything??
I just ordered mine from Billetflow. Not only do they have awesome quality pulleys but they pre machine the idlers so you don't have to grind a thing. Idlers are like 35 or less I think.
Also,
I have some questions conciring the intense kit. Say i install the kit, and have a full exhaust system (catless) and an intake. Is there any way to tweak the A/F to make it a touch richer or leaner? Also, how do you go about getting the $10 cobalt member discount?
#36
