Question on ss/sc
Stock Injectors Stock Pulley Stock Tune and all the bolt-ons - Saturn ION RedLine Forums
Get bigger injectors that can handle the boost.
6,500 rpm
Def on the stock injectors for sure, but 42's & 60's (depending on pulley size of course) can handle it.
I guess when I meant they should get tuned, I assumed they would do everything (pulley, injectors, etc.). I should have been more specific
You should still shift at 6300 on the stock injectors even after a tune.
Last edited by Staged07SS; Aug 24, 2011 at 01:13 PM. Reason: Automerged Doublepost
This is a good point to reiterate. The stock injectors are basically maxed around the factory 6500 redline. It is unwise to spin the engine past this point with the factory injectors as they will be effectively static.
WTF. And you have a car with a supercharger on it! Maybe its time you trade it in on a YUGO and you can say to all your friends YOU GO WE ALL GO
not my fault i can handle a whopping 210 hp and make a 90 degree turn at 70mph. (amazing i know right? it was kinda beast mode and slo mo)
Iceberg
Sep 29, 2015 12:33 PM
